The Advantages of Floor Coupled Up-Firing Speakers
Old 3rd March 2013, 11:09 PM   #1881
ScottG is offline ScottG  United States
Originally Posted by graaf View Post
and not just that - also cardioid radiation pattern
When I tried cardioid designs for the midrange, I could never get around the over-damping effect of the pressure-release in a small volume "enclosure".
It always seem to "suck the life" out of the drivers, and blunt spatial aspects. Yet when I read the reviews, somehow the designers have overcome this..
-peaks my curiosity.
perspective is everything
Old 3rd March 2013, 11:15 PM   #1882
Here is a radial design that will necessarily "flood" the room (despite the waveguides):
Morrison Audio fine audio speakers and electronics.
Notably one of the loudspeakers from Morrison, (..and they are all essentially similar), was concluded as having the best sound-staging effects of *any* loudspeaker ever reviewed by The Absolute Sound.
Old 4th March 2013, 06:50 AM   #1883
graaf is offline graaf  Poland
graaf's Avatar
to understand Helsinki 1.5 it is useful to take a look at their precedessors in the Gradient line
first of them all were Gradient 1.1 or 1.0:
more: Myydyt kaiuttimet - Classic Audio
take notice of a much bigger midbass unit, operating as a dipole in the range of 250<1500 Hz, its acoustical center closer to the floor than in the case of Helsinki
in fact all the subsequent models in the line (1.2, 1.3 etc.) used the same configuration, Helsinki is the first to employ a smaller midbass in a cardioid enclosure
"high phooey and hystereo" - Yascha Heifetz
Old 4th March 2013, 07:59 AM   #1884
Juhazi is offline Juhazi  Finland
Juhazi's Avatar
One of the inventions of 1.3 was to use the 15" driver at frequenciens where it shows remarkable directivity! This added to dipole function and upwards tilt... The tweeter section is a line array configuration with gradual low-pass, also giving more vertical directivity. The bass is downfiring, thus giving no floor reflection but utilizing floor boost!
A genius' work of art! 35 years ago!
It is my dream to clone this and utilize minidsp
AINOgradient speaker project
Old 4th March 2013, 08:48 AM   #1885
graaf's Avatar
exactly - no need of a fancy cardioid enclosure
no point in cloning - I believe we can make it better!
Old 4th March 2013, 08:59 AM   #1886
Elias is offline Elias  Finland
Elias's Avatar
What is your recipe of the ideal ?
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 4th March 2013, 09:50 AM   #1887
Juhazi's Avatar
^^ is this rebirth worthy of an own thread? I´d like to participate!
I don't have skill and measuring system to make a xo myself, it would be a pleasure to participate in a project like this. I have listened to a pair of 1.3s quite a lot at my friend's some 14 years ago. I could buy originals but "signature" remake with modern technology and knowhow would be more fun!
Old 4th March 2013, 09:53 AM   #1888
lolo is offline lolo  France
lolo's Avatar
...... and with some Koskenkorva!
Old 4th March 2013, 10:08 AM   #1889
graaf's Avatar
I believe that floor reflection must me attenuated and low-passed as much as possible
I also believe that (and this belief seems to have been confirmed independently by Mr Croft research quoted earlier in this thread) - that we need a certain optimal ratio of direct to off ceiling reflected sound
this ratio depends on the speaker directivity, the angle at which it fires up to the ceiling and the listening distance
I also believe in the necessity of time-coherence in the sense of the wavefront fidelity - all early reflections should preserve the shape of the initial transient that reaches the listener as the direct sound
so I believe that we need an adjustable (with regard to the angle of orientation of its acoustical axis), controlled directivity and an essentially time-coherent loudspeaker, not time-coherent on axis like some, but in the sense stated above
in the light of the foregoing Gradient designs aim in the right direction but don't meet the above criteria as strictly as it is possible
Old 4th March 2013, 10:12 AM   #1890
graaf's Avatar
and some humppa music!
Eläkeläiset - Elan Humpalla - YouTube
The Advantages of Floor Coupled Up-Firing SpeakersHide this!Advertise here!
Using a diffuser cone for up-firing speakers tspringer99 Multi-Way 19 23rd July 2014 02:04 AM
Floor Standing Speakers. gurpreetsingh Full Range 11 12th June 2012 06:42 AM
side/ rear firing speakers Good/Bad? mcmahon48 Multi-Way 1 6th February 2009 12:28 PM
How far can the driver of a down-firing sub be from the floor? The Paulinator Subwoofers 11 16th May 2007 08:10 PM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 02:13 PM
