The Advantages of Floor Coupled Up-Firing Speakers
Old 2nd October 2012, 01:38 PM   #1721
markus76 is offline markus76  Germany
Banned
By the way, James Croft proposed two solutions to the "sound from the floor" problem in the thread I had linked earlier. Please see http://www.faktiskt.se/modules.php?n...110176#1110176
I don't think the HRTF-approach works reliably but the Allison-like approach of placing the woofer/mid boundary-coupled and the tweeter at ear height looks promising for a wide dispersion design.
Old 2nd October 2012, 01:59 PM   #1722
graaf is offline graaf  Poland
graaf's Avatar
Do You read the thread before posting Markus?
Everything Mr Croft has to say on the matter have been already posted here.
Old 2nd October 2012, 02:04 PM   #1723
graaf's Avatar
Originally Posted by Elias View Post
There are many systems employing 3D stereo field. Ambisonic comes to mind first Others include 3D vector amplitude panning, like the one proposed by Lokki.
and what about the precedence effect?
I don't understand the point. Sound direction can be localised without any reflections. In Snell Type 1 there is strong direct sound from the tweeter, which can result to image localised low.
I thought we have agreed that what is needed is optimal direct/reflected sound ratio in "Type 1" there was strong direct sound but also strong reflected sound
and the sound was NOT coming from the floor
Yes there was a big difference in the treble range. I posted measurements long ago in some of these threads.
treble range that is precisely? how big? I ask because it seems to be important for the FCUFC to work best
Old 2nd October 2012, 08:29 PM   #1724
graaf's Avatar
Is your tweeter a horn tweeter ? How is the directivity ?
it uses Dayton H12RW 12" waveguide IIRC so itīs effectively a virtual ceiling tweeter, an entirely different FCUFC implementation than "Type 1"
Old 2nd October 2012, 10:21 PM   #1725
Elias is offline Elias  Finland
Elias's Avatar
As a rule of thumb, reflected and delayed sound must have a little bit higher amplitude than the direct sound in order the direct sound not to be perceived as a sound source.
In snell type 1 I cannot see how this would happen ? And, there is no vertical directivity pattern plots of Snell speaker ?
The speaker I was using for the test started to have narrowing directivity somewhere above about 3-4 kHz I think.
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 2nd October 2012, 10:30 PM   #1726
Banned
If the dispersion is really wide then there are higher order reflections that are likely lumped together (perceptually). Would be interesting if someone could take the time to look at this more thoroughly.
Old 2nd October 2012, 11:07 PM   #1727
gedlee is offline gedlee  United States
gedlee's Avatar
Elias - you have to be careful quoting those results because, as I have pointed out before, they refer to a shift in the "principle source location" and say nothing about image blur or coloration - the two things that I consider the most important. The precedence effect is widely over used in audio to explain things. Most of the work that was done simply does not apply to the real problems in audio - imaging, coloration and spaciousness.
Earl Geddes Gedlee Website
Old 3rd October 2012, 12:20 AM   #1728
ScottG is offline ScottG  United States
Localization is exactly what he is describing (it's not just implied, it's expressed):
"Image Blur" and "Coloration" from reflections are however interesting topics.
"Image Blur" I'm aware of - a diffused effect of an "image". Which I rarely find to be far from reality (..when compared to a real sound source with eyes closed listening). In fact sometimes the result seems to be closer to reality, but occasionally worse depending on how close the loudspeaker is to the wall and how reflective the wall is.
As for "Coloration" though, at least at higher freq.s.. I'm somewhat at a loss here for a "definition".
I have heard conditions where there were broad-band changes (like a "tilted-up" freq. response) - but not something I'd characterize as a "coloration". Moreover most people seem to adapt to the alteration from "flat".
The only time I've heard of significant coloration at higher freq.s was from direct sound (i.e. the combination and combing effects of L+R, particularly on vocals), not from any reflection. (..of course modal effects and floor/ceiling "bounce" will almost certainly provide a "narrow-band" coloration, but that's at lower freq.s.)
perspective is everything
Old 3rd October 2012, 02:30 AM   #1729
speaker dave is offline speaker dave  United States
speaker dave's Avatar
The goal with the Type 1 is to have the reflected sound in phase with the direct. Its no different than ground plane measurements. As you take an ear level mic and move it towards the ground the air path and the ground bounce path get closer in time. The cancellation nulls move up in frequency and, eventually, all audio frequencies are in phase. The direct and reflected become inseparable.
The woofer can be above the floor surface a few inches, but the tweeter can't, hence the ramp and the notch to get the tweeter center at the reflecting plane.
On top of it all you get a bonus +6dB.
David S
Old 3rd October 2012, 04:45 AM   #1730
CLS is offline CLS  Taiwan
Yes, correct, that's what I'm using. Thank you.
BTW, I don't know why the diffused HF can sound pretty clear. For example, the triangle at the far corner of a big orchestra is sounding just the way it should -- distant, small, crisp and clear. Both spaciousness and imaging are very good.
Flooder tweeters aside, the directivity of the central channel DML panel is very wide, too. The panel is quite large (180x90cm), with a very uniform half-space radiation.
So basically the HF in this (very reflective) room is everywhere. Why can I pinpoint that little tiangle in the whole (sound-)space? I can't explain.
The Advantages of Floor Coupled Up-Firing SpeakersHide this!Advertise here!
Using a diffuser cone for up-firing speakers tspringer99 Multi-Way 19 23rd July 2014 03:04 AM
Floor Standing Speakers. gurpreetsingh Full Range 11 12th June 2012 07:42 AM
side/ rear firing speakers Good/Bad? mcmahon48 Multi-Way 1 6th February 2009 01:28 PM
How far can the driver of a down-firing sub be from the floor? The Paulinator Subwoofers 11 16th May 2007 09:10 PM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 03:13 PM
