The Advantages of Floor Coupled Up-Firing Speakers
Old 17th February 2011, 07:39 PM   #1521
Elias is offline Elias  Finland
Elias's Avatar
Who will install thousands of loudspeakers in his livingroom wall For real?
- Elias
Originally Posted by syntheticwave View Post
However, living in an anechoic chamber may result in trouble with some unregenerate spouses. Much more clever seem, construct a common model from recording room and playback room, as in the Holophony procedure. By those object based procedure, a combination of the model based and data based approach allows, constitute an common approach. In the near field of an large WFS loudspeaker field behind the silver screen, the playback room acoustics become subordinated matter. Thus, the common model allow subtracting playback room acoustic. Is easily comprehensible in this little animation:
http://www.holophony.net/pictures/WF..._principle.swf
We are at the work to build that. I hold the patent for the procedure since more as five years. The result will be the physikal reconstruction of the spatial sonic field.
Regards H.
Liberate yourself from the illusion of two speaker stereo triangle
Dipole Bass vs Monopole Bass Stereophonic Sound from a Single Loudspeaker 3 Speaker Linear Stereo Matrix Wavelets
Old 17th February 2011, 08:05 PM   #1522
syntheticwave is offline syntheticwave  Germany
Send a message via ICQ to syntheticwave
- Elias
..you shouldn't blab your wife, what is covered behind the silver screen. Simply say, a band would be playing!
H.
Wave Field Synthesis and Holophony
Old 17th February 2011, 08:29 PM   #1523
Elias's Avatar
Never mind the silver screen But who will install thousands of loudspeakers behind it You also need thousands of amplifiers, one for each speaker.
- Elias
H.
Old 17th February 2011, 08:48 PM   #1524
markus76 is offline markus76  Germany
Banned
Ambisonics has been doing the same since 70's. To separate the spatial sounds from the rendering.
- Elias
Is there anybody else besides you that still remembers Ambisonics?
P.S. Ambisonics and the 3DAA approach are not the same. Ambisonics is more like wave field synthesis with a limited number of loudspeakers whereas 3DAA really separates sound objects from playback. Ambisonics could act as a renderer for 3DAA content.
Old 17th February 2011, 09:05 PM   #1525
- Elias
...you understand the principle, thanks for interest.
The loudspeakers are fixed in modules. The modules include the amplifiers. At four watts each we have four kW total power. Because of the perfect Loudspeaker adaptation ,the dynamics neraly unlimited, in principle.
The whole unit is connected via one light cable at the computer, which is rendering the 32 input channels to the 1024 speakers. That is not really a problem, from technical point of view, but also not really cheap.
H.
Old 17th February 2011, 09:14 PM   #1526
Banned
Now you just need to convince the whole movie/audio industry of investing in completely new recording facilities/equipment in order to produce exclusively for your system. Piece of cake
Old 17th February 2011, 09:46 PM   #1527
...no other way remains for true spatial audio.
H.
Old 21st February 2011, 09:46 AM   #1528
The Prof is offline The Prof  United Kingdom
Default Measurements
While on the subject of reproduction and measurements, I would like to present a few points for serious consideration. In order not to waste forum space here, and perhaps go off at a tangent, I would invite you to take a look at "Measurements and the Environment" at my blog <http://sound-unboxed.blogspot.com/>.
Surely these are highly personal views, but if there are kindred spirits who share at least some of the points of view, it could lead on to a renewed look at measurements and our understanding of sound and reproduction.
I hope the more knowledgeable among us would start an appropriate new thread to address such 'borderline' issues.
Most sincerely.
Old 9th March 2011, 04:52 AM   #1529
Default Sound and Sense and Measurements
While on the subject of sound and sensible measurements, permit me to urge you, if you have a few minutes to spare and are open-minded about some 'lateral thinking' on stereo and realism, to visit < Sound... unboxed ! > and share your thoughts.
Whether you agree or disagree, I guess you too might share some of the problems raised by commonplace questions about reproduction, realism and the role of 2-channel stereo as we know it and implement it.
Thanks and regards.
Old 9th March 2011, 10:49 AM   #1530
Banned
Please do just that and stop misusing this thread to advertise your blog.
The Advantages of Floor Coupled Up-Firing SpeakersHide this!Advertise here!
Using a diffuser cone for up-firing speakers tspringer99 Multi-Way 19 23rd July 2014 03:04 AM
Floor Standing Speakers. gurpreetsingh Full Range 11 12th June 2012 07:42 AM
side/ rear firing speakers Good/Bad? mcmahon48 Multi-Way 1 6th February 2009 01:28 PM
How far can the driver of a down-firing sub be from the floor? The Paulinator Subwoofers 11 16th May 2007 09:10 PM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 03:13 PM
