First Crossover attempt
Old 11th April 2008, 04:01 AM   #1
LightwaveDude is offline LightwaveDude  United States
Default First Crossover attempt
This is my first attempt at designing my own crossover. It's pretty horrible, but honestly, I don't know what I'm doing. This is an attempt at teaching myself what to do. It's a theoretical build on a system I'd love to put in my car someday parents, money, and time permitting. I'd love to have suggestions on what I should be doing differently.
I'm using the Dayton Reference RS225-4, the Dayton Reference RS52AN, and the Tang Band 1166SJ as my model drivers.
Here is a picture of the crossover.
Old 11th April 2008, 04:05 AM   #2
Here's a picture of the frequency response I've been able to attain.
Old 11th April 2008, 04:08 AM   #3
I'm looking for advice on what I should be doing, how to go about arranging my crossover, and most importantly, why it should be done. I've tried reading tutorials online, but most of them stop with the basic textbook crossovers. Very little is taught about what to do to tweak the design. Sorry if this seems a bit basic, but I learn best when I can ask questions on things I don't understand (can't really do that on a published web article). Thanks for any advice.
Old 11th April 2008, 03:31 PM   #5
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
An interesting a good first try...shouldnt be too hard to make it a bit better
First you need attenuation on mid driver
I dont understand why you have 12uf before series inductor on mid lowpass
You may not need such steep filter slopes
sometimes we know very little, and sometimes we know too much
Old 11th April 2008, 05:44 PM   #6
R.I.P.
Hi, because he has not simmed the amplifier melting input impedance, /sreten.
Old 11th April 2008, 05:54 PM   #7
kevinkr's Avatar
Smoke on the water.... Ouch... Nice not so little capacitive load directly on the output of the amplifier.. I seriously doubt any car amplifier would survive long with that load connected to it.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 11th April 2008, 06:12 PM   #8
joetama is offline joetama  United States
I understand the want to learn how to build a crossover.
But, Since you are putting this in a car why not just go active.
Are you planning on running a subwoofer also?
Because if you aren't a lot of good headunits (which you probably already own) will do a 3-Way system pretty nicely.
In my car I have a fully active 3-way system. It is nice to be able to tune delay and change things on the fly.
Just my $0.02.
Old 11th April 2008, 06:55 PM   #9
badman is offline badman  United States
badman's Avatar
Guys, that's why he's asking.
Lightwavedude:
What they're talking about is that you have 2 capacitors on the midrange that would cause the amplifier to see a short at some high frequency (coupla khz).
This will kill many MANY amps.
On the woofer, I take it Cz1 and Rz1 are for impedance compensation? If so, Cz1 is way too small, 10pF is a negligible capacitance. 10-100 uF range is more appropriate.
I would omit the woofer resistor.
There are a lot of other issues here, including the location of what appears to be a parallel notch filter on the mid. That with the inductor and cap to ground, in parallel, is what's causing the short.
Your phase response is all over the place. Did you pick values, assemble what 'looked good', and then simulate it for as flat an amplitude response you could get? If so, that's not the way to design a crossover. Existing topologies are available to help you get a better performing loudspeaker. You already have the drivers simulated so you just need to plug in some calculated values for a 'normal' crossover, and tweak the values to match the characteristics of the speakers in your simulation.
I'd suggest starting with a tried and true speaker/crossover design, such as one from www.zaphaudio.com, and also some time spent researching. The links sreten gave are good, spend some time reading, looking at various crossovers with various speaker combinations, play around with your software.
A book every speaker builder of any sort should keep on hand is vance dickason's loudspeaker design cookbook. Not just a summary of designs, it has many practical studies, explanation of theory, and other content. I believe the 6th edition is on blowout at www.madisound.com
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 11th April 2008, 08:37 PM   #10
kevinkr's Avatar
I definitely second badmans recommendation of Vance Dickasons book. Highly recommended.
First Crossover attemptHide this!Advertise here!
My ESL attempt SM7UYJ Planars & Exotics 144 4th March 2010 02:22 PM
My first attempt mikee55 Chip Amps 4 26th March 2006 12:16 AM
Horrible crossover attempt. Netlist Multi-Way 12 2nd October 2004 09:52 PM
for my first attempt : Magnetmaz Pass Labs 13 19th November 2002 10:23 PM
