I have been reading through some DIY projects and thought I would try one myself. I have a very small budget so I figured I would use some speakers I have lying around the house since it would be my first project. When looking through my speakers I ran into a problem. I have heard that you cannot mix 4ohm with 8ohm speakers. Is this correct?
I would be using a Bose 2.75" tweeter(8 ohm), a Bose 6.5"mid/woofer(8 ohm), and a 12"SVC Cerwin Vega subwoofer(4 ohm). Is this a waste of time? Thanks for your help. |
#2 |
theres nothing actualy bad about it.. that i know of.
aslong as the efficiency ratings are similar of the various speakers and also as long as ur amp is 4ohm rated not many ohms-too much current ul probably find that the vega may be more efficient than the tweeter and mid. :-) |
#3 |
Um, lesse... if your amp is 8 ohms, then the two 8 ohm speakers in parallel, + the 4 ohm sub in series, will get a good impedance match.
In the real world, this probably won't work right, and something is telling me you'd need a capacitor across the sub (as opposed to a series inductor) to shunt higher frequencies away from it, and pour into the other speakers instead. Tim |
#4 |
Banned
Or you could bi-amp... one for the woofers, 1 for the mids and tweets.....
#5 |
There is no amp per say rightnow. The speakers will be playing straight through my receiver ( Technics SA-GX170 ). I beleive the rating on the receiver is 8 ohms. Does that mean that the sub will not play correctly?
| newbie Q | memphissound | Multi-Way | 7 | 17th August 2006 12:36 PM |
| Yet another newbie | hell0un1verse | Introductions | 1 | 30th March 2006 06:31 PM |
| SET kit for newbie | Grahamt | Tubes / Valves | 9 | 7th June 2004 03:22 PM |
| Newbie w/ sub ?'s | toenail | Multi-Way | 2 | 8th March 2003 02:10 PM |
| newbie post, but hopefully not a newbie question | wiredcur | Solid State | 3 | 24th August 2002 11:49 PM |
| Page generated in 0.07720 seconds (75.56% PHP - 24.44% MySQL) with 10 queries |
