fabricated steel enclosure bad for driver performance?
Old 11th April 2008, 03:52 PM   #11
mrkahn is offline mrkahn  United States
Originally posted by Svante
The magnetics is not a problem. Anyway, stainless steel is not magnetic, right?
The bigger problem is the resonant properties of steel. It has very little losses, which probably will result in very narrow/loud resonances, possibly at rather high frequencies (depending on wall thickness).
It is a cool idea, but I would be careful to attach some sticky material to the inside of the box walls to increase the losses in the wall and thereby attenuating the resonances.
Hey Svante,
The wall thickness I plan to use is 1/2" steel (13mm) Very thick and heavy. I have a lot of this material left from a job and I can cut it on my waterjet. I plan on seam welding it into a closed chamber so no losses will occur.
That being said, I dont know what type of resonance I will be dealing with or at what frequencies? any thoughts on how to calculate or anticipate what I will end up with?
with that thickness of metal would an inner layer of damping compound be necesarry? I am scared of building a Bell that at a specific frequency it rings like crazy... Aluminum does not seem to do this in my previous experiments but steel has interesting audible characteristics when excited.
fabricated steel enclosure bad for driver performance?Hide this!Advertise here!
Welded steel frame sand filled enclosure JoeM Multi-Way 29 9th July 2009 12:57 PM
F200A in spherical steel infinite baffle enclosure sharpi31 Full Range 10 3rd September 2007 11:59 AM
enclosure tuning performance crippledchicken Subwoofers 0 8th August 2006 04:35 AM
Steel for DIY driver speakerguy79 Multi-Way 8 3rd June 2006 11:29 PM
Using steel enclosure as negative desireable? franjy Parts 0 2nd July 2005 04:35 PM
