I would like to build a pair of sealed box MTM D'Appolito style speakers using 7" vifa woofers and tweeters much like th Lipinski studio monitors. Do I need to section off each section of drivers or do I simply mount them in one sealed box? This idea is still brewing so any suggestions are welcome. Also where can I find more information about the D'Appolito configuration? Thanks in advance.
#2 |
(I don't know for short, but) You can read D'Appolito white papers (Google it) on the net.
Do you have this document yet? Lipinski studio monitors - Stereophile L-707 Review http://lipinskisound.com/Reviews/Ste...7%20Review.pdf Also look for Solist MTM Kit using Scan-speak drivers from Madisound, http://www.madisound.com/solist.html and Westlakes pro Westlake Audio BBSM-5F with dual 5". http://images.google.com/images?hl=e...-8&sa=N&tab=wi (http://www.westlakeaudio.com/Speakers/speakers.html) |
#3 |
moksha if u choose sealed box to build. Please you build two sealed boxs. if the vent box u can build like madisound link.
#4 |
thanks for the responses. Do you folks know what material Lipinski used for the tweeter surrounds? The website states that its Belgian foam. I know its for reducing the edge effect so would acoustical and/or non-acoustical foam work?
So far I have the 7" Vifa woofers and the Vifa 25mm xt tweeters. I'ts going to be sealed boxed with a first or second order butterworth with inductance compensation. |
#5 | |
Hi, That will turn out completely wrong. You could do a lot worse that following the schema here : http://www.zaphaudio.com/audio-speaker16.html http://www.rjbaudio.com/Audiofiles/FRDtools.html http://www.geocities.com/woove99/Spkrbldg/ |
#6 |
sreten, could you explain why you think that the sealed box low order butterworth combination is a bad idea? It seems like the Lipinski monitors implement something like that.
#7 | |
Lowish order acoustic alignments are not the same as low order electrical filters. You likely would exploit the bass drivers inductance for baffle step compensation. Looking at the stereophile article the treble electrical filter is ~ at 4 or 5KHz for a low order alignment and the bass filter due to baffle step will far lower than 2KHz due to BSC. The net result is lowish order acoustic, with the bass mid reinforcing the treble above the c/o point (2Khz) to a degree, you can only arrive at this by measured and / or good simulation. With low order acoustic slopes tweeter excursion is an issue, one that the XT25 is not particularly good at, quoting Zaph : Quote:
#8 |
Do not use the XT25 with a low order crossover unless above say 4500Hz. !!
For the tweeter in a 7" MTM you need a Seas 27TDFC or something similar with plenty of grunt. Which 7" Vifa woofer are you considering? If you are considering the P17WJ sealed and asking it to do bass and mids you will seriously muddy its mids and you would really need to make the tweeter do a LOT of the upper mid work. I would not recommend this approach. |
#9 | |
Vifa XT25TG30-04 Ring Radiator Tweeter Vifa PL18WO-09-08 7" Woofer http://www.partsexpress.com/projects...la/nebula.html |
#10 | |
thanks for the input folks. The Vifa midrange is a MG25 7" glass fiber woofer and the tweeter is the XT25. My goal was to clone the lipinski monitors with the time aligned stepped baffle (I figure by aligning the acousitical centers). I was thinking about using some material like whispermat for the stepped tweeter baffle.
So sreten, you say that the Lipinskis are electronically crossed at 4k? I read the article and it said somewhere that it was crossed at 2k? I could be wrong. Anyway my goal as I said earlier was to clone the lipinskis so some low order crossover is in order. steten how would you reccomend I do the crossover? Once I get the drivers I will test the actual impedance in free air as well as in the cabinet using speaker workshop. I'm also having the tweeter baffle adjustible so that I can adjust for best phase response. The lipinskis also have the tweeter out of phase which leads me to suspect that it uses a 2nd order L-R crossover. Also streten, and others any suggestions for achieving this: Quote:
| FS: x25 Vifa 5" Drivers + x2 Diamond Audio 5.6 Hex Eton Drivers | omarmipi | Swap Meet | 0 | 19th November 2007 04:21 AM |
| ACI 12" sub drivers (2), Vifa 8" poly (4), North Creek D26 tweeters (2) | nodiak | Swap Meet | 2 | 29th October 2007 03:45 AM |
| F/S Vifa 5.25" Drivers | amorrow | Swap Meet | 5 | 26th February 2004 08:18 PM |
| First Project HT using Peerless/Vifa Drivers? | needle | Multi-Way | 8 | 9th May 2002 01:50 AM |
| Vifa Car Drivers for Home Theatre Project? | needle | Multi-Way | 0 | 24th April 2002 02:41 AM |
| Page generated in 0.15364 seconds (68.12% PHP - 31.88% MySQL) with 11 queries |
