MTM project using 7" vifa drivers
Old 8th April 2008, 02:58 PM   #11
R.I.P.
Originally posted by audio_moksha
So sreten, you say that the Lipinskis are electronically crossed at 4k?
I read the article and it said somewhere that it was crossed at 2k?
I estimate the electrical high pass to be ~ 4Khz, but could be wrong.
Acoustically the crossover point is 2KHz see fig 3.
/sreten.
Old 8th April 2008, 03:06 PM   #12
audio_moksha is offline audio_moksha  India
any specific suggestions sreten? I was thinking of starting off somwhwere with a low order butterworth for the tweets and maybe a LR for the midrange. However if the tweeter is phase inverted shouldn't the crossover be a 4th orfer L-R? Once again thans for all your expertise and suggestions.
Old 8th April 2008, 03:17 PM   #13
Inductor is offline Inductor  Portugal
Inductor's Avatar
Vifa midrange is a MG25 7"
Was there an "Vifa MG25 Yellow Glass Fiber cone"? I didn't find it... for the specs.
Old 8th April 2008, 03:44 PM   #14
R.I.P.
For the low pass your first issue is baffle step compensation.
A symmetric driver aligned 4th order L/R acoustic response has
the two drivers connected in phase, 2nd order L/R out of phase.
Checkout Zaph's crossovers here : http://www.zaphaudio.com/
Note that most of the crossovers are slightly assymetric to make
up the phase difference betwwen the drivers, except the ZD5
which has a treble delay ladder, they are all acoustic targets.
Specifying an electrical target is fairly meaningless.
Also note the lipinski does not have symmetrical acoustic slopes
at all, but nevertheless seems to work very well in practise.
If you can get your head round SW then the following should not be too bad :
http://www.rjbaudio.com/Audiofiles/FRDtools.html
http://www.geocities.com/woove99/Spkrbldg/
/sreten.
Old 8th April 2008, 04:14 PM   #15
Inductor's Avatar
...or is it a 2xVIFA MG18WK/SK09-08 8ohms connected in parallel(?!)
http://www.tymphany.com/archives/10
Another Xreference
http://www.shine7.com/audio/speaker.htm
Old 8th April 2008, 04:23 PM   #16
rob3262 is offline rob3262  United States
rob3262's Avatar
/sreten.
Sreten, could you please expand on this?
I don't have a fundamental understanding of accoustic vs electrical orders.
- Rob
Scientific Principle and Common Sense
Old 8th April 2008, 05:21 PM   #17
R.I.P.
- Rob
/sreten.
for an example see http://www.zaphaudio.com/audio-speaker16.html
The acoustic target is 4th order L/R at 1.7khz.
The actual crossover is 2nd order electrical combined with the drivers
responses in box - this response includes baffle step and there is
no compensation of driver inductances or the tweeters impedance
peak at its Fs as this is not necessary. (as its a ferrofluid model).
(not the case for the XT25 see http://www.zaphaudio.com/ZD5.html )
The components in the crossover do not conform to any electrical
filter (e.g. Bessel, L/R, Butterworth etc), what counts is the total
acoustic result taking all factors into consideration.
See all of Zaph's other designs where this principle is applied.
/sreten.
Old 8th April 2008, 06:39 PM   #18
Yes this is the driver I had in mind; seems like what Lipinski uses.And sreten, thanks so much for all the information.
Old 9th April 2008, 01:30 AM   #19
Inductor's Avatar
I hope you can find it because it was discontinued.
http://www.tymphany.com/mg18sk09-08
Old 9th April 2008, 04:21 AM   #20
Inductor's Avatar
Default 2-WAY X-Over MG-VIFA L-Pad
You have here a good base to work on...
MTM project using 7" vifa driversHide this!Advertise here!
FS: x25 Vifa 5" Drivers + x2 Diamond Audio 5.6 Hex Eton Drivers omarmipi Swap Meet 0 19th November 2007 04:21 AM
ACI 12" sub drivers (2), Vifa 8" poly (4), North Creek D26 tweeters (2) nodiak Swap Meet 2 29th October 2007 03:45 AM
F/S Vifa 5.25" Drivers amorrow Swap Meet 5 26th February 2004 08:18 PM
First Project HT using Peerless/Vifa Drivers? needle Multi-Way 8 9th May 2002 01:50 AM
Vifa Car Drivers for Home Theatre Project? needle Multi-Way 0 24th April 2002 02:41 AM
