Old 3rd April 2008, 03:20 PM   #1
Default help with tweeter compensation
I have a ferrofluid dome tweeter branded "Tave" with the attached frequency response. It will be crossed over at 5KHz with an active LR 24dB/Octave X-over. Any suggestion on how i could compensate the actucal frequency response (actively preferably)
Some of the tweeter data
Fres:1346 Hz
Qts:2.590
Qms:12.882
Qes:3.241
Inductance:0.046mH
L1 inductance:0.042mH
Series resistance:0.659Ohm
DC resistance:4.39Ohm
P:s due to my location its hard and extremely expensive to get better tweeters.
Old 4th April 2008, 01:08 PM   #2
you can apply a 6 dB Highpass Filter at 4...5 Khz and a notch
in series of the speaker for the peak.
Maybe imdedance should be equalized with RC parallel to
the tweeter.
Should work.
Oliver, RFZ believer (?)
www.dipol-audio.de
Old 4th April 2008, 02:55 PM   #3
Saturnus's Avatar
First I would try with a passive 1st order filter high pass filter at around 4½KHz, that will make the frequency response almost completely linear from 1½KHz to the massive spike at 12Khz. Not sure what to do about that though.
HV Probe compensation Elvee Everything Else 7 23rd November 2007 07:47 AM
Boundary Compensation... FirebirdTN Multi-Way 8 8th March 2006 03:43 PM
Offset compensation? Vg Multi-Way 2 5th June 2002 11:26 PM
Page generated in 0.07681 seconds (59.78% PHP - 40.22% MySQL) with 11 queries
