High-efficiency 2-way...possible with 12" woofer?
Old 30th March 2008, 03:00 AM   #1
dmitriy167 is offline dmitriy167  United States
dmitriy167's Avatar
Default High-efficiency 2-way...possible with 12" woofer?
Since I'm using a tube amp, i was thinking of ditching the 86 dB MorePees (Peerless 850122/Morel MDT20) I have now and getting something a bit more efficient. My target is around 92-93 dB into 8 ohms. It looks like the new Peerless HDS tweeter can do the job, but I need a good woofer that is efficient enough.
Assuming that I would run the tweeter without padding and that I would use 4 dB or so of BSC (should be around 300Hz due to cabinet width), the woofer would have to be 96-97 dB efficient, into pro sound territory. My budget for the woofers is no more than $160 per piece.
Would the tweeter and a 12" woofer integrate well? I'm concerned about beaming issues. My guess is that if I put the tweeter into a waveguide and then pad the response down a la Zaph, I would be able to get good power handling at a low crossover frequency. However, that requires more design difficulties and so I would like to avoid a waveguide if possible.
Woofers I have been looking at:
Eminence Delta Pro 12A:
http://www.partsexpress.com/pe/showd...number=290-510
This one looks decent, but I can't get an F3 below 55Hz or so. Also, it has a 5 dB peak at 2.5 kHz that needs knocking down.
Eminence Kappa 12A:
http://www.partsexpress.com/pe/pshow...56&ctab=2#Tabs
Same peak as Delta Pro, Fs is lower, but Qts is too low for good bass response. I don't have the woodworking skills or space to do a horn.
Eminence Kappa Pro 12A:
http://www.partsexpress.com/pe/showd...number=290-424
Decent response, low Fs, small peak at 2 kHz, but Qts is too low to be useful.
Eminence Deltalite II 2512:
http://www.partsexpress.com/pe/showd...number=290-593
This one is interesting. Bass models perfectly for what I need, but it has a nasty rising response curve/breakup node. How would I get the phase tracking right if I knock it down with an inductor?
B&C drivers all seem to have a Qts that is too low, so I can't use those.
Beyma 12BR70:
http://profesional.beyma.com/ENGLISH...pdf=12BR70.pdf
Slightly low sensitivity, but just what I might need, although midrange distortion looks a bit high.
Beyma 12G40:
http://profesional.beyma.com/ENGLISH...?pdf=12G40.pdf
Looks nice, has low distortion, BEAUTIFUL response, I can massage a good bass out of it, but out of my price range.
I don't have hardware measuring tools, so I would have to rely on Jay_WJ's method of simulating response. Since I'm using a tube amp, a flat impedance curve is essential. I played around with some of the Excel spreadsheets, and I'm not an expert at designing, but I'm OK with this being a learning experience.
Does anyone have any ideas/comments/driver suggestions?
Old 30th March 2008, 03:59 AM   #2
ttan98 is offline ttan98  Australia
I am using NOW,
2-way open baffle,
tweeter is a compression driver with 105db spl and horn combo, you can pad it down. I suggest you use this approach, rather than std tweeter with 92-93db spl. If you use waveguide I am sure you have to do lots of adjustments and tweaking, if you don''t have appropriate equipment it is going be difficult.
my woofer is al' cheapo type, but you can use Eminence Delta 12" or equivalent as you suggested.
In open baffle configuration I have to use 2*12" per side to give me the bass. Hence my configuration is TWW, similar to Eminent Physics speaker system.
I cross at around 1.7Khz. Properly designed x-over the combo will sound good. I use digital x-over so easy to adjust.
cheers.
Old 30th March 2008, 04:23 AM   #3
ashok is offline ashok
ashok's Avatar
" tweeter is a compression driver with 105db spl and horn combo "
What compression driver do you use and which horn ? I've been looking at some but they don't seem to go too low.
Thanks.
AM
Old 30th March 2008, 04:42 AM   #4
Thanks.
There are a few good quality comp driver around, B&C and Beyma brands come to mind. These brands are recommended my many visitors here.
I am using B&C with good sucess, many others here also give their thumbs up. I have direct experience with B&C model, I am NOW playing B&C comp. driver,
model DE250 x-over around 1.7Khz, it can go lower to 1.5Khz. Also using B&C al cheapo horn ME10(lowest rec. x-over around 1.5Khz). If you have more money buy the DDS, Eng -90 horn, I heard it is very good.
DE250 is summary is very smooth and dynamic.
also I bought the cheaper model, DE10 x-over much higher at 2-2.5Khz. also very good.
All the B&C models above you can get from Parts Express.
Old 30th March 2008, 04:43 AM   #5
Originally posted by ttan98
[BEminent Physics
cheers. [/B]
Should read Emerald Physics...
Old 30th March 2008, 03:25 PM   #6
dmitriy167's Avatar
ttan98,
The DE250 looks like a good driver. I might end up using that, but I have questions. Firstly, can I use a round waveguide like the Dayton if I get an adapter? From the description, it might sound less nasal. Link: http://www.partsexpress.com/pe/showd...number=270-310
Secondly, all the horn drivers have twin peaks in the impedance response. How would I smooth that out?
Also, any additional woofer advice to get a decent low end?
Old 30th March 2008, 10:17 PM   #7
Originally posted by dmitriy167
ttan98,
I have tried the PE 10" circular horn, it is cheap and not very good if you expect high std. You are living in the States and able to access to high quality horn, I suggest the following:
option 1
cheaper, try RCF H100 horn at $28 each you can get it from Loudspeakers Plus. I am getting a pair. I have a test report on the compatibility with DE250, report with good result, except for a slight bum around 2Khz. You can equalise it easily. You x-over over as low as 800Hz!
option 2
DDS eng 1-90 circular horn is more expensive at $99 each from US speakers or cheaper at this site:
http://www.assistanceaudio.com
Both are good horns.
I use active x-over and don't have problems with impedances.
Old 30th March 2008, 10:24 PM   #8
also,
http://www.assistanceaudio.com/09_kits.html#tiny
this site offers package deal with their BMS and DDS horns and Ciare drivers at discount prices. Many people report the BMS 4550 to be very good too.
I believe the Ciare CIARE 12.00nd W1, not cheap is quite good, Audio Kinesis uses it in Stormbinger speakers.
You may find this site very useful.
I good combo is BMS4550, DDD eng 1-90 horn, and Ciare 12.00nd W1 driver. This will sound very dynamic and open with correct x-over. I am considering this combo for a similar system like yours. Not cheap but gives you good sound.
There you are more choices.
Old 31st March 2008, 06:17 PM   #9
Brett is offline Brett
Brett's Avatar
US Speaker are also a good source for the DDS flares.
Old 31st March 2008, 06:48 PM   #10
ingvar ahlberg is offline ingvar ahlberg  Sweden
ingvar ahlberg's Avatar
The B&C drivers are good, i have used the DE900 a lot at home matet with 12" drivers Eminence Kappa pro12, good, Beyma 12LX60, imo among the best 12" youŽll find. Have changed hf to Beyma CP380M wich i find even better, also cheaper. Dont forget the Eminence PSD2002 driver, real value for money! You have to xo it at 1500 or higher thou.
Ingvar
High-efficiency 2-way...possible with 12" woofer?Hide this!Advertise here!
High Efficiency 10" Mid Suggestions Impious Multi-Way 13 10th March 2009 08:21 AM
High efficiency 15" TomatoBangBang Multi-Way 72 11th November 2008 06:55 PM
UK source of inexpensive 3" or 4" driver - high efficiency sreten Full Range 9 23rd November 2005 03:15 PM
