Beginning of some DIY speakers - Page 9 - diyAudio
Old 16th April 2008, 02:50 PM   #81
To mount those tweeters I wound up buying the largersize bit and ran it down to a local machine shop and had him cut it down.
Best $15 I've spent.
Your miters look VERY NICE..........
Later
Rich
Old 16th April 2008, 10:01 PM   #82
Send a message via MSN to cyberspyder
Bought some pre-stain today and will test it.
Brendan
Old 17th April 2008, 04:50 AM   #83
OK, so I just tried the combo on a piece of scrap, and the results were pretty shiesty..I don't know if I like the stain, as it's still a nasty colour...my guess is that the birch is really white, compared to other wood species, so there's no yellow in the wood to compliment the stain. What about oils? I can try it with tung oil tomorrow.
Brendan
Old 17th April 2008, 08:05 AM   #84
Default Coatings..
Hello cyberspyder, Again, I think you should try the spar urethane. Someone here mentioned their disdain for Minwax products. I cannot speak for all Minwax products, as I have not used them all. However, the Helmsan Spar Urethane has done great for me. If you apply it correctly, it should not produce a "blotchy" finish. I have never seen it produce any blotches on a wide variety of materials. As I said, it has a slight Amber to its appearence, but this can be desireable on lighter woods for sure. It provides a finish much tougher than stains. You can stain first and topcoat with the SU if you want to darken the wood, but I would try it bare first. I believe it comes in three different textures, flat, satin(good choice for speakers), and gloss. I mostly have used the satin, but whatever the case, each has served it's purpose well. I have some items that are over 15 years old that show no yellowing or degredation of the substrate, despite their constant daily exposure to sunlight. Have fun. -discreteouts
Old 17th April 2008, 02:50 PM   #85
npapp is offline npapp  United States
Hi, I should have been more specific on my Miniwax comment. I meant specifically the miniwax stains that you may want to avoid. I use Miniwax poly and Miniwax wax on some projects. My personal experience has been that the MW stains do not give as even of a finish. If you can find Cabot or Zar stains (I have no professional involvement in either brand) and give them a try you should see an obvious difference. C & Z stains seem to be slower drying and are more oily, while the miniwax is watery, splashy and soaks into the wood very quickly.
Old 17th April 2008, 08:42 PM   #86
OK, so I tried the tung oil today, and I must say that it's a better finish overall..I would get the spar urethane, but they're out of stick at the closest HD, so why not just stick with what I got? Will return the stains today, here are some pics:
(top: stain, middle: plain wood, bottom: tung oil)
Brendan
Old 17th April 2008, 10:02 PM   #87
mightym is offline mightym  United States
mightym's Avatar
Location: Checotah, Okrahoma former home of the Okra Fest
Default Staining
I hope you are able to achieve results that are pleasing to your eye, they are your's after all.
That being said, I will describe an alternative, one you are free to reject.
This is only one way of doing this and I'm sure others have different ways.
Start with sanding to 200/220, then apply a "spit coat" of half shellac and half alcohol ( not Isopropol, but methanol ). If you want to start to add a warmer tone use amber shellac. When this dries, sand it again to same as the start to remove any raised grain. Put on another spit coat, let it dry. light steel wool to smooth or go a little finer sandpaper, then wipe down and apply a gel stain to your taste in color. steel wool again and wipe on two coats of poly, light buff with the steel wool optional between coats.
The shellac will fill the grain somewhat, but won't seal it, so it will take the stain. The Gel stain can be wiped on and is easy to control the color intensity.
Good luck!
It looks like very nice work so far.
John
Old 18th April 2008, 04:33 PM   #88
jwmbro is offline jwmbro  United States
jwmbro's Avatar
Hey, how are you going to make the hole for the midwoofer?
I was looking around at what tools I can use, and I was wondering if I could just use a 4" hole-saw to drill it, instead of using a router with a jig (one of these - just bigger). Does anyone know if this would work?
Old 18th April 2008, 05:53 PM   #89
Hole saws that big can cost a lot of money compared to a router bit. Personally i find the router easier to use because the hole saw can get clogged with sawdust easily, and it can splinter a veneer.
If you make a circle cutting jig for the router it cuts the hole really fast. Also if your using a router, don't cut all the way through, leave ~1mm of extra wood to hold the center chunk and punch it out after cutting.
Old 18th April 2008, 07:30 PM   #90
jwmbro's Avatar
well, the 4" hole saw costs 20 bucks, I don't think I can build a jig + buy router bits for much cheaper than that...
also I'm not going to be drilling through veneer. It would seem to me like it would be faster to just center the drill bit, and drill down, than to route around the hole....
beginning of a car amp rwaudio Car Audio 8 27th March 2007 11:10 AM
Beginning my aleph 30 bobsinclar Pass Labs 85 4th November 2006 11:01 AM
beginning dome406 Solid State 0 2nd November 2004 06:12 PM
In the beginning ..... gpsmithii Pass Labs 15 24th November 2003 05:34 PM
beginning with class a Opie Pass Labs 3 10th May 2002 08:39 PM
Copyright ©1999-2017 diyAudio
