Beginning of some DIY speakers - Page 11 - diyAudio
Old 24th April 2008, 03:32 AM   #101
Send a message via MSN to cyberspyder
Bah, I'm glad if I can achieve half of that....
Old 24th April 2008, 06:32 AM   #102
neb001 is offline neb001  United States
To be fair, I think meguire's polish has a bit of filler in it
Old 25th April 2008, 07:50 PM   #103
Yes, but I'm pissed/sad/angry currently. I was a bit careless on the router today when routing my pieces, and whaddaya know...disaster. I'm pissed at myself because I shoulda routed everything BEFORE I cut them up into little pieces, and now that decision has come to haunt me. Long story short, the piece dove headfirst into the bit TWICE, and I now have some divots that'll give my speakers some character....Bahumba. I don't have anymore wood so that's that.
Also, as you can probably see/guess, I routed all the pieces today. Oh, and I redid the routing/finishing on another scrap piece, and the results were nothing short of spectacular.
Brendan
Old 30th April 2008, 02:46 AM   #104
April 29, 2008
-Sanded the routed edges today, along with the external surfaces. Rubbed another coat of oil onto my test piece.
Brendan
Old 30th April 2008, 03:29 AM   #105
Nice work! You should enjoy these for a long time.
I first used Baltic Birch ply on a pair of large horn speakers over 20 years ago. At the time I think I used a "diamond" Varathane finish (semi gloss). They still look great after all the years.
-Joe
Old 7th June 2008, 03:03 PM   #106
Default Combined update
May 26
-Quite a while since I've updated this...I had alot of school summatives to do, so this has been put on the back burner...but FEAR NOT! I will have it done before the end of the school year. Only have to glue these suckers together now:
June 6
-Glued together, and everything sanded smooth, true and square. Ready for tung oil application.
Brendan
Old 10th June 2008, 12:47 AM   #107
June 9
-First coat of tung oil put on (seems kinda blotchy, but that disappears when sunlight shines on them), binding posts and port tube secured in enclosure, pics coming in a sec when I complete the front baffle tonight.
Brendan
Old 10th June 2008, 12:52 AM   #108
MJL21193's Avatar
Looking Good
Old 11th June 2008, 07:44 PM   #109
June 11
-Drilled my tweeter holes, drum sanded them, did some manual sanding after. It turns out 120 grit sandpaper with a tiny jar of Tamiya model paint fills up the tweeter hole EXACTLY. A bit of sanding, and I was left with some perfect holes. One thing I don't like about the Dayton tweeters is that the body is slightly flared, so it makes it harder to get the actual diameter. Also, tweeter recesses on the back completed an holes for drivers drilled. Second coat of oil put on, but no pics of that.
Brendan
Old 12th June 2008, 06:58 AM   #110
warnsey is offline warnsey  Australia
I love seeing threads like these.
Keep it coming
beginning of a car amp rwaudio Car Audio 8 27th March 2007 10:10 AM
Beginning my aleph 30 bobsinclar Pass Labs 85 4th November 2006 10:01 AM
beginning dome406 Solid State 0 2nd November 2004 05:12 PM
In the beginning ..... gpsmithii Pass Labs 15 24th November 2003 04:34 PM
beginning with class a Opie Pass Labs 3 10th May 2002 07:39 PM
Copyright 1999-2017 diyAudio
