Hi folks,
after a couple of hours before my registration I'm here, asking for your help. I'm building a pair of bookshelf loudspeakers, 2-way bass-reflex. System Fb is 50 Hz, I've made calculations resulting in a certain lenght/certain diamenter vent. I had to buy a specific vent made for small cabinets, featuring dimensions to fit into my boxes, but once arrived a new problem has born: this vents are non cylindrical but slightly taperes, a true truncated-cone! Declared as 6,6 sq.cm (on the smallest end) but actially larger at the opposite flared side. Is there any formula to calculate the right vent lenght, considering if cutting it will result in a diameter increase? thanks Gianmaria |
#2 | |
#3 |
Here's the drawing attached....
#4 | |
On your drawing the left inner part as the (main) diameter, for an adjustable length that you can calculate with the software. Just to say, use the other tube side. |
| Vent length question | DAMIC | Multi-Way | 4 | 20th September 2006 05:53 AM |
| Martin J King's Ported Sheets-Vent Height Question | kelticwizard | Multi-Way | 7 | 25th April 2006 12:49 PM |
| Vent machs(easy question!) | xstephanx | Subwoofers | 12 | 1st February 2005 03:27 PM |
| Double Chamber Reflex Vent Question | Guss | Multi-Way | 16 | 26th June 2004 07:44 PM |
| Page generated in 0.41016 seconds (13.92% PHP - 86.08% MySQL) with 11 queries |
