Old 26th March 2008, 02:39 PM   #1
luvdunhill's Avatar
Default Speaker connectors for use with external crossovers
any recommendations on a connector for a 3-way which will utilize a external crossover? I'm probably going to house the crossover in the stand for now by placing the connector on the bottom of the speaker, but will also cut a canal for the wires to be routed out through the back in case the crossover was in my rack. Any reason why a barrier strip wouldn't be a good choice here?
Old 26th March 2008, 02:47 PM   #2
auplater's Avatar
Default connectors
I've used both barrier strips and banana plug/jack sets. I prefer the banana jacks , gold plated (for obvious reasons), as they are easier to setup and modify.
same xover, different look....
John L.
"...His brain is squirming like a toad..." Jim Morrison
Old 26th March 2008, 03:53 PM   #3
Andersonix's Avatar
Default Re: Speaker connectors for use with external crossovers
Not really. But only you knows your abilities to keep wires from shorting and getting mis-identified and cluttered. I like the Euro terminal block style for bare wires and protecting from bare screw heads (but not so convenient to hang an alligator clip on). I think you should just make things easy on yourself regarding access and simplicity (and appearance) and make things tidy and sturdy after you're done experimenting.
Apex Jr has some light duty dual banana posts for $1 that might be a temp solution (and he also has Euro terminal blocks cheap). Nothing wrong with screw-on wire nuts either (except they wear out the wire strands after too many re-connections).
Old 28th March 2008, 12:43 PM   #4
ianpengelly's Avatar
You could always consider the 8 way speakon connectors, as these will remove any chances of shorting, etc.
With the plans I am drawing up for my two ways, I plan to use the 4 way versions to connect the external crossovers to the cabinets.
Old 30th March 2008, 02:02 AM   #5
OzMikeH is offline OzMikeH  Australia
On my 2 way speakers I use 4 pole Speakons, they are very good and relatively cheap. The only downside is they stick out a long way. they need a cup or an angled mount if you wish to put the backs of your speakers close to the wall.
You could use one of those + a set of banana plugs for the remaining driver.
If you want a single connector perhaps a 6 pin XLR.
Help some guys with funny hair bang two rocks together really hard.
http://athome.web.cern.ch/athome/LHCathome/whatis.html
Old 2nd April 2008, 12:29 AM   #6
Inductor's Avatar
Default Toa PA Speaker
any recommendations on a connector for a 3-way...
...routed out through the back in case the crossover was in my rack. Any reason why a barrier strip wouldn't be a good choice here?
Why not?... with a good legend/speaker marks to prevent wrong doings.
Old 2nd April 2008, 12:58 AM   #7
R-Carpenter's Avatar
Send a message via ICQ to R-Carpenter
s
Extreme speaker connectors peranders Parts 30 14th November 2010 03:10 AM
B&O speaker connectors SY Parts 13 10th October 2007 07:37 PM
External passive crossovers... In front of the power amplifier? luvdunhill Multi-Way 8 27th July 2007 12:58 AM
External Crossovers... Mos Fetish Multi-Way 18 16th April 2004 02:18 AM
Power connectors for external PS net-david Chip Amps 1 1st April 2004 04:44 AM
Page generated in 0.14377 seconds (56.91% PHP - 43.09% MySQL) with 11 queries
