JBL 2482 phenolics OR horn loaded cone driver for low-mids?
Old 25th March 2008, 11:15 PM   #11
pkm is offline pkm  New Zealand
http://www.volvotreter.de/
The conical could easily have strong panel /mouth reflections in top of band-
3.4m wavelength 100hz, up to 0.34m at 1khz
Perhaps
- last 1/3 of flare,double included angle 'eases' the pattern flip a little.
id be tempted to squeeze the vertical to achieve a more CD response horizontally
DIY Axially symmetric oblate spheroid CD waveguides, in solid Oak
http://www.audioheritage.org/vbullet...d.php?p=196422
http://www.xlrtechs.com/dbkeele.com/...xp%20Horns.pdf
Old 26th March 2008, 06:48 AM   #12
pk is offline pk  Denmark
Originally posted by Magnetar
The 2123 is warmer, and more 'romantic' sounding in the lower range. It also will keep up well with the rest of the system. The 2482 will cover a much wider range though and would be superb mated with the B&C treble. - hmmmmm Those straight bass horns to me are a dilemma. I always used folded horns for the low bass and kept them separated Yours probably sound better in the bass but appear to be difficult to mate with the rest of the system. Looking at it I think I would place the low mid horn up high tilted down and cross over around 150 cycles using a 10 , below it a large format compression driver around 600-800 cycles then to the little B&C. The upper mid and treble horns would go between the bass horns and the mid bass horns.
Hi Magnetar,
Thanks for sharing your experiences! I think my bass horns do sound very good indeed. I never had such punch with direct radiators. I just think that they - probably because of the length of the horns - do not sound as open as I would like above, say, 150-200 Hz or so. If I go for the cone low-mid, then your suggestion sounds very good indeed!
Kind regards
Peter
Old 2nd July 2015, 08:57 PM   #13
pocketchange is offline pocketchange  United States
My results with a trachorn: 400 to 6000 Hz. with 2482. pc
Old 3rd July 2015, 10:00 AM   #14
vinylnvalves is offline vinylnvalves  United Kingdom
I will support the statement that the jbl2482 won't go lower than 300hz. I have had a number of different cd's in big horns. The BMS 4592 goes lower. A cone such as the audax pr170 goes down to around 200hz, which I have tried but found it sounded thin.
Old 3rd July 2015, 09:38 PM   #15
Scott L is offline Scott L  United States
Default cd vs mid vs mid-bass
A compression driver loaded into a large horn may show response that low, but, will it play the note ? Of course not, it can't grip the air.
The pr170 series drivers are mid range drivers, again, not made for anything
low.
A 10 inch mid bass, especially horn loaded, will play the music. However,
I can't say whether a 10 inch is the optimum size.
Old 4th March 2016, 01:44 AM   #16
$$Maan is offline $$Maan  Denmark
I wish I could see that pic of the basshorn, I just arrived to Aarhus DK, I'd say go paper cone for warm vocals.
Second rebirth of thread...
JBL 2482 phenolics OR horn loaded cone driver for low-mids?Hide this!Advertise here!
How do single driver (read loaded) horn speakers actually sound? hugz Full Range 50 11th July 2015 08:57 PM
New member with a question about horn loaded compression driver-type speakers... munkittrick Car Audio 15 27th May 2009 12:49 PM
horn loaded driver Z AndrewT Multi-Way 21 23rd December 2007 05:32 AM
Back Loaded Horn with Pro Coax Driver djdan Multi-Way 10 15th October 2004 01:45 PM
Phase plug for cone driver in mid-bass horn design? mefistofelez Multi-Way 2 18th October 2003 07:59 PM
