Hi
I nowadays got my hands on an old suspended project. It was an instrument cabinet. And I still have an unresolved question about its xovers. If I divide HF out of a 2 way xover in to two, via an other 2 way one, I would actually make a plain 3 way one, right? Here I want to divide HF shelf which starts from 3.5 kHz into two with 5.0 kHz cut point. Looks simple but I'm still suspicious Any ideas? Thanks in advance Temporal And here is the diagram: |
#2 |
You will end up with very little output from the 6A, it is essentially superfluous. The APT with the right horn can work with the right bass driver at either crossover frequency. the croosovers cannot be used together in any effective manner I can think of. |
#3 |
Thanks for reply
Well.. I got my inspiration from this "Figure 3" at http://www.trueaudio.com/st_xov_1.htm and I thought my combination may work. But of course you're right. There's indeed a little output from the mid driver |
#4 |
At last I managed to draw a schematic of my combo
I hope It makes easier to notice any significant weirdness in the wiring. To me point A could be connected to point C instead of B : ) without any effect on frequencies, coz first two caps in the line have higher values than the ones at HF filter. Cheers Temporal |
#5 |
Hi again
Could someone please recommend a measurement software to check phase response via a sine sweep (freeware if possible I use RMAA for other measurements but it doesn't have this feature I'm afraid Thanks Temporal |
| trying to build an unusual PA | maestrodave | Everything Else | 9 | 22nd August 2008 03:11 AM |
| Unusual TT. | G | Analogue Source | 3 | 10th February 2008 10:26 PM |
| Unusual Driver | ShinOBIWAN | Multi-Way | 4 | 8th November 2005 01:14 PM |
| An unusual hum problem. Need help. | Shoog | Chip Amps | 30 | 14th October 2004 09:55 PM |
| Unusual | BJ Johnson | Solid State | 2 | 13th May 2003 06:08 PM |
| Page generated in 0.11189 seconds (65.94% PHP - 34.06% MySQL) with 11 queries |
