Finishing my speaker stands was wonderful. I can have my garage back for parking autos. This project was not without its issues and the project did bring up some what ifs. Like I wish I would have included the sub woofers into this stand.
#2 |
I originally painted one of these stands with kilz black satin and it did not look good so I had to resand and paint with rustoleum satin black. Notice the color of the rustoleum satin black diy b3s next to the kilz satin black stands.
#3 |
They look great CC ! Nice work.
Judging by the scenery, I'd bet you're in the S.E side of things and within 5 min of Airline hwy... 7/10 |
#4 |
Thanks I try.
nah Im not close to Airline Hwy. I am in east br thou. All the new houses in BR look alike. I put these stands outside for three hours to harden paint and pollen covered them. Bad time of year to keep things clean. It took all day to clean the garage of all the black overspray. It was a mess. Im not sure if youve seen my 5.1 system I built for my home gym but Ill include a picture. My next project will be a small entertainment center for the gym (nutmeg) and a credenza type piece (black) for my bed room. These pieces will be made of solid ash. I would like to match the nutmed paint with some stain for the small entertainment center. I tried to make my own stain by spraying a can of paint into a container and adding mineral spirits to thin then applied to the ash then wipe off but that did not work. For the credenza piece Id like to try the black aniline dye with dead flat clear lacquer. I saw Joe L use it on his speaker project and it really looked nice. My only concern is would it penetrate ash enough to get the dark look Im after. http://www.avsforum.com/avs-vb/showthread.php?t=170942 http://www.avsforum.com/avs-vb/showthread.php?t=170942 Any one else interested in building a pair of these fear not they were no harder than building a set of speakers. |
#5 |
Is that surround setup the one featured on Partsexpress ?
Looks very nice BTW. I have not made many of my own stains, but I did have good luck with mineral spirits and artist acrylics. It may be worth a small experiment or two. 7/10 (born and bred in EBR) |
#6 |
Nah John "Zaph" Krutke designed these B3S speakers http://www.zaphaudio.com/audio-speaker18.html.
The sub is a dayton 10" dvc http://www.partsexpress.com/pe/showd...number=295-485 and the sub amp is a 100watt dayton http://www.partsexpress.com/pe/showd...umber=300-802. This set up is nice for a small room. Seattle has the right humidity to feel like BR all you have to do is open up a container of motor oil and set it ablaze to get the smell of BR. What city in its right mind would put a petroleum plant in the middle of the city? I guess thats what our politicians call intrastructure. The plants get all the people feeling ill so they keep the medical fields busy. On a positive note Baton Rouge did get a new cancer treatment machine to experiment on the public. Baton Rouge General’s Pennington Cancer Center is the first, and so far only, U.S. facility with Siemens Healthcare’s Artiste radiation treatment device. http://www.2theadvocate.com/news/business/16698696.html Im sure Siemens didnt pick Baton Rouge because it has a low cancer rate per capita and they just put that machine here cause they liked the smell of our brown air. |
#7 |
True, so very true...
This past fall I spent almost three weeks in that hospital with my dying dad. I really miss home, but it'll be too soon if I ever have to step foot in there again. sb |
#8 |
So have you done any diy projects??? Pictures???
I wish I would have built these instead of the b3s project. http://www.zaphaudio.com/audio-speaker19.html Hi-Vi W5 / Vifa D27SG15 My only problem is that I have to wall mount my speakers in the gym and the living room. It sort of limits what I can build. My living room is so accustically unfriendly and space limited I was sort of domed from the start. I ended up just purchasing a http://www.klipsch.com/products/deta...ii.aspxklitsch set up with a http://www.klipsch.com/products/deta...gy-sub-10.aspx sub. Considering the small size of these speakers I must say they do the job. Had I found a design online like them I most certainly would have diy a set up. My confidence low and the amount of available diy small HT speaker designs online I bit the bullet and purchased a BB special. I ate at uncle o's seafood for lunch and drusillas seafood tonite wow It was good. I would miss the seafood if ever i left louisiana. I guess you have a nice selection of seafood in seattle. |
#9 |
Im building a credenza to match these speaker stands. This piece will support my 48" projection tv. I had to have it raised 1'4" so I could use the tv in my bed room. Long story tv swapping at its finest. I am building this piece out of mdf to keep cost down because it will be a throw away after the tv fails. What use would a 1' 4" credenza have besides what Im using it for.
#10 |
I have the base completed finally. It took forever because I was hammering out the wall bkts while building this.
| Speaker stand help | Bull | Everything Else | 2 | 13th March 2007 07:22 AM |
| Pictures of my completed H-frames | DIY_newbie | Multi-Way | 7 | 18th September 2005 11:20 PM |
| Speaker stand... | Bogie | Subwoofers | 6 | 31st January 2005 03:52 AM |
| 2-Way Stand Speaker Suggestions... | dezzz | Multi-Way | 8 | 29th December 2003 06:55 AM |
| Diy Speaker Stand Plans Here! | Rjwz28 | Multi-Way | 0 | 24th April 2002 05:44 AM |
| Page generated in 0.13165 seconds (71.37% PHP - 28.63% MySQL) with 11 queries |
