DIY Completed Speaker Stand Pictures - Page 2 - diyAudio
Old 9th April 2008, 05:47 PM   #11
Im moving up now. The only thing holding me back it clamps.
Old 10th April 2008, 02:45 AM   #12
I have the credenza front back and sides on. A few more supports and Im off to the top.
Old 11th April 2008, 01:42 AM   #13
Out of 800 visits one person had something to say.
Old 11th April 2008, 01:57 AM   #14
Slow going today. I wrestled with the router I have on my router table. The motor screws vibrated loose. A bit got stuck into the chuck and the router table hole was to small for the round over bit I wanted to use so I tried to dremmel it bigger. That turned into a hassle all in itself.
I managed to put on my trim work and prime the inside of the credenza. This thing is really getting to be heavy. Hope I can lift it after Im finished adding mdf.
Old 12th April 2008, 02:44 AM   #15
Ok today I routered the tops. I painted the inside and back black and I added a chamfered edge to my corners. Tomorrow this thing comes together. I guess priming is next.
Old 12th April 2008, 02:45 AM   #16
Hitting the edges like this really dresses the corners up.
I still have a sub woofer to diy for this project. I was going to just build it into the cedenza but the vibration would prolly have messed up my projection tv.
Old 14th April 2008, 12:49 AM   #17
I finally get to glue the top onto this credenza. Notice that I recessed the top to accommodate the wheels on the projection tv that will go on this piece. Last thing I need is the tv to roll off of it after I went to all this trouble.
Old 14th April 2008, 12:51 AM   #18
Close up of recess. I used the jig I made for the recess in the b3s project. It worked out perfect. Ill prolly glue some felt into the recesses.
Old 15th April 2008, 02:18 AM   #19
I finished my sealer coats. I sprayed on two coats of Kilz then I sanded piece smooth. I then sprayed one more coat of Kilz. I will spray three coats of rustoleum primer then sand smooth again. That spray can handle is a life saver on my button finger.
Old 16th April 2008, 04:25 PM   #20
OK Im through sanding primer. There is point where you have to say its good enough. Id be here till christmas sanding if I wanted it perfect. Speaking of christmas I managed to bring a little xmas cheer to my day. I ran out of brown paper and had to resort to my wrapping paper stock. Guess I shouldnt have grabbed the disney paper. To late.
Speaker stand help Bull Everything Else 2 13th March 2007 07:22 AM
Pictures of my completed H-frames DIY_newbie Multi-Way 7 18th September 2005 11:20 PM
Speaker stand... Bogie Subwoofers 6 31st January 2005 03:52 AM
2-Way Stand Speaker Suggestions... dezzz Multi-Way 8 29th December 2003 06:55 AM
Diy Speaker Stand Plans Here! Rjwz28 Multi-Way 0 24th April 2002 05:44 AM
Copyright 1999-2017 diyAudio
