Old 22nd March 2008, 01:07 PM   #1
dome406 is offline dome406  United Kingdom
Default Velleman K4700
I am building this speaker protection circuit and just wondered the purpose of R23, R24, R25 and R26 (see attached diagram) and weather i need to include them.
In the instruction manual (see instructions1) it says to include them if:
If the amplifier to which the module is to be connected has a simple power supply (asymmetrical supply) i.e. an amplifier with output elcos, the following resistances has to be mounted...
My amplifier is a non inverting lm3875 with a regulated 18V 0 -18V power supply so i am guessing it doesnt need these resistors since the supply is symmetrical ?
What confuses me is what elcos mean i thought it might mean electrolytic capacitors? but am unsure. Also my amplifier has 2.2uF non polarised capacitors if this makes any difference.
Hope someone can explain
Thanks very much
Old 22nd March 2008, 01:12 PM   #2
Heres the other image.
Old 22nd March 2008, 10:16 PM   #3
Thago is offline Thago  Belgium
Hi
I used the same Velleman K4700 kits in Pass Aleph 2 monoblocs, which have a symmetrical +45V - 0 - 45V power supply, thus meaning that both + and - are 'hot' (see attachment).
I did'nt use the resistors you mentioned, the K4700 works fine.
Old 24th March 2008, 12:38 AM   #4
thank you Im still not quite sure what they are needed for but will try without the resistors.
Old 24th March 2008, 01:14 AM   #5
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
these resistors are needed for bleeding output caps , which are certainly used if amp is made with non-symmetrical PSU ;
better to charge/discharge them through resistors , than through speaker coils, don't you think?
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery
K4700 PCB (Speaker Protection) GeorgeP1111 Multi-Way 1 8th September 2008 11:09 PM
FS: heatsinks, velleman K4700, bosoz PSU, etc cowanrg Swap Meet 6 17th January 2007 03:15 PM
velleman k4700 speaker protection circuit cyteen Solid State 6 27th May 2005 04:16 PM
speaker protection velleman k4700 wuffer Multi-Way 2 1st March 2005 06:09 PM
Velleman K4700 kit problem supernet Parts 2 5th November 2004 08:13 PM
Page generated in 0.07982 seconds (75.83% PHP - 24.17% MySQL) with 11 queries
