EnABL - Technical discussion - Page 140 - diyAudio
Old 18th January 2013, 01:00 AM   #1391
frugal-phile(tm)
planet10's Avatar
Originally Posted by tuxedocivic View Post
By nonlinear I mean harmonic distortion
By using a global term for something very specific that is but an infitesamal aspect of the global term is very limiting to one's thinking of the whole picture.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 18th January 2013, 01:16 AM   #1392
tuxedocivic's Avatar
Like I said, sorry. Harmonic distortion is often referred to as nonlinear distortion in speaker testing, although there are other tests and form of nonlinear distortion. I was asking you what you think needs to be measured.
White noise is 20 to 20,but I'm not sure what software can resolve the two signals. That's why separated inputs would be better. I suppose you could do bands of sound rather than a single frequency. 1000 to 2000 at 0db, 2000 to 3000 at -10, 500 to 1000 at -20db, etc.
Old 18th January 2013, 01:17 AM   #1393
I do a similar test method to measure compression which you are familiar with. I find it quite useful.
Old 18th January 2013, 01:24 AM   #1394
frugal-phile(tm)
planet10's Avatar
Baby steps...
There are lots of examples where measures, theories, etc are simplified until doing it is possible with existing tech, but far too often the simplification is then used to catagorize the much more complex phenomenom. That is a trap we want to avoid.
dave
Old 18th January 2013, 01:36 AM   #1395
But it might show something. And if it did?
If it didnt then we're neither ahead nor behind. I don't see a trap?
Old 18th January 2013, 01:44 AM   #1396
frugal-phile(tm)
planet10's Avatar
It might very well, if nothing else, help push measurement techniques. Start simple and then with each baby step push towards the ulimate goal learning from the successes and failures of earlier runs.
I am encouraging you, not discouraging you
dave
Old 18th January 2013, 02:00 AM   #1397
Cool
I may give this a go on a crappy and nice driver of similar size, use, and sensitivity to see what happens. Problem is getting WAV files that do what I need.
Old 18th January 2013, 02:06 AM   #1398
Yes, lots of good measurement techniques for observing low level effects present close to stimulus.
None are used here. Avoiding measurements perpetuates time available for filling empty thread.
Old 18th January 2013, 02:18 AM   #1399
frugal-phile(tm)
planet10's Avatar
Please detail.
dave
Old 18th January 2013, 03:30 AM   #1400
Single sine, multiple sine, swept sine, multiple swept sine, band pass MLS, shaped bursts, and various combinations.
As more sine waves are added to signal, potential IMD components would grow geometrically, but each IMD component taps energy from formant harmonics, pulling measured harmonic value down.
Example:
Burst stimuli are used to explore steepness of crossover slope in rejecting harmonic and IM distortion with small full range driver:
Peerless 2" full range is run with two conditions: Linkwitz-Riley 24dB/oct high pass filter and with 1024 point FIR high pass filter. Each condition is also brick wall filtered with 4096 point FIR 1kHz low pass filter. The upper trace shows a sea of output above 1kHZ for LR4 high pass filter consisting of harmonic distortion and IMD. FIR results show defined much lower simple harmonic peaks against the true noise floor.
Signal passed to driver with low slope 24dB/oct filter and no signal above 1kHz results in significant output above 1kHz. Reality is dirty byproducts continue down below 1kHz. Most of this is induced by relatively low stimulus passed in driver resonance region. When this is rejected as with steep FIR filter, bandwidth is narrower, less cluttered, and produces far fewer distortion components, and at significantly lower level.
This translates directly to listening experience with these crossovers. FIR filter allows much more power before driver gets rough to listen to.
Good old battle of bandwidth and dynamic range.
Copyright 1999-2017 diyAudio
