Recently I both drivers (Scan Speak 18w8535-00 + 9500). First I make Troels Gravesen cabinet http://www.troelsgravesen.dk/download/2.5_Clone.pdf. I tried many types of crossovers but withouth result. Sound was muddy, undertone without expanse in middlem, bass was deep but without attack (energy). I think the cause of this was small volumen of the cabinet. After nearly a week of work I quit of this cabinet.
Next solution was Event http://www.audiocomponents.nl/speake...g/event_1.htm. Results was better then previous but sound was bad though. I have opossite sound from previous. Middle was wide but without warming and definition, bass was deep but without definision. I worked on dumping but without visible results. There is last solutin. Close cabinet. I searched internet but without results. I wish to build BR or TL but I'm in the dead end. I have not equipment to mesure T/S parameters and work further. I'm count on you people Any hint will be highly woth. best regards |
#2 |
Here is link corrections
1. http://www.troelsgravesen.dk/download/2.5_Clone.pdf 2. http://audiocomponents.nl/speakers/s...ng/event_1.htm |
#3 |
It’s hard for me to understand what the problem is. Undertone, muddy sound? Do you mean the tweeter was lower then you use to? Classic clone, so to speak uses D2010/8513, not D2905/9500.
I know that some people used 9500 with great success but it does require a different crossover. I myself build the box to the actual original size, used variable density panels and 2 braces. Stuffing was moderate and I kept port section almost clear of it. I am not having any problems at all. Speaker sounds pleasant for what it is. |
#4 |
azoran, what boxes do you have (internal dimensions)? and size of ports if you played w/them allready, you can change after you are set. Size of the front baffle also is important? Did you look at a stronger bass like the one I post in the bottom? Are you building BR (bass reflex box)? You might have a good list of xover parts allready. Post it if you want to save some money but this is not important at this stage. I don't know the xover you are playing with, is it Troels on page 28? Post some detailed information. You can also pad the front of the tweeter for a better appearence with cork (or velvet or some other foammy material as in the 8513) to entertain yourself. List of reference from ScanSpeak: SS Classic 6.5" Midwoofer 18W/8535-00 http://www.tymphany.com/18w-8535-00 SS Classic 0.75" Tweeter D2010/851300 http://www.tymphany.com/d2010-851300 SS Classic 1" Tweeter D2905/950000 http://www.tymphany.com/d2905-950000 ProAc Response 2.5; 38L, Fb=40Hz original http://highend.puslapiai.lt/?speakers/8 8535 ProCub; 47L, Fb=29Hz (BR) http://highend.puslapiai.lt/?speakers/7 |
#5 |
I'm working on Troel project 1000x200x265 (19mm MDF) with tube on the back on 430mm from the bottom.
Tube diameter 70mm x 135mm. http://www.troelsgravesen.dk/downloa...t_drawings.zip Yes I tried Xover from Troel project page 28. My problem isn't Xover. I think cabinet is the problem. I followed your last link and I want to try 8535 ProCub; 47L, Fb=29Hz (BR) design but can't find cabinet drawing. If you need any other details ask free. thanks for your effort |
#6 | |
Here it is a rough calculation using WinISD. You can use this settings with your existing box, but (your) port is not that favourable at such high frequency (35Hz). To bring it to 47L/32Hz you need a circ. vent of 70mm-d/200mm-l or one of 50mm-d/90mm-l. An idea is to pad the inside with a soft foam pipe of the same size or to make it longer about 196/200mm length. I have one that states "75mm port with variable length" from 135mm to 255mm (max.), "PL 75" that is in reality a 66mm int. diametre from www.caliber.nl. You can also use cardboard tubes. Do you have the ports/vents cut already in the speaker? For a 47L/30Hz a 50mm/108mm or a 70mm/230mm, for a 47L/29Hz a 70mm/248mm, for a 50L/32Hz a 70mm/180mm. This if they are free ends with end correction (E.C.) of 0.614. Take all this only as a guide not like the best set-up. I am also making sure you are using the size of the box (volume) in liters w/out the volume of the (internal parts) speakers, vents, xovers, braces, wall thickness. I assume your baffle is 1000x200mm. |
#7 |
Visualisation for the baffle step compensation. Rough estimate with the Edge software.
Baffle dim 200x1000mm with driver centred (in baffle) at 750mm height. |
#8 |
I'm planing to build cabinet 1000x216x311 (outher dimension) with 18mm MDF with driver centred (in baffle) at 750mm height. Where to place vent on front or on rear panel and on which height? When I have this data I'll resume my work, then follow work on Xover.
#9 |
Don't forget bracing of cabinet. And use 2x19mm for front baffle.
#10 | |
Width: 225mm Height: 1020 mm Depth: 255mm http://www.geocities.com/diyproac25/dimensions.htm You can use your own dimensions dough. |
| Proac Clone | SergeDufour | Multi-Way | 0 | 22nd November 2006 09:08 PM |
| Proac Clone Q's | elilindner | Multi-Way | 0 | 3rd December 2003 02:19 AM |
| Proac 2.5 clone questions | wilsonj | Multi-Way | 4 | 7th June 2003 10:07 AM |
| Question regarding ProAc 2.5 Clone and Tempo 2 Clone | zoooh | Multi-Way | 5 | 11th March 2003 08:19 PM |
| Proac 3.5 clone | Buhl | Multi-Way | 1 | 4th January 2003 10:05 PM |
| Page generated in 0.15308 seconds (68.95% PHP - 31.05% MySQL) with 11 queries |
