How do you secure your cables inside your cabs?
Old 12th March 2008, 02:50 PM   #1
dublin78 is offline dublin78  United Kingdom
Default How do you secure your cables inside your cabs?
I am wondering what method people use for securing the cables inside their cabinets.
I am just completing my TLs using scanspeak 18w4531. I am basically wanting to avoid the wires slapping around inside for years to come. Maybe this is not a problem.
Duck tape will loose it adhesion eventually. Silicon is possible but messy. Cable ties with anchors screwed down would be ok but they do not secure all along the length.
Ideas?
Old 12th March 2008, 03:07 PM   #2
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
Mount your crossover part way up your enclosure so the wires go over to the drivers not up to them and keep your leads only as long as to mount the drivers easily. If you are still worried, wrap some insulation around them with tape to make them heavier and stiffer.
planet10 needs your help:
Let's help Ruth and Dave
Old 12th March 2008, 03:35 PM   #3
BlueWizard is offline BlueWizard  United States
Here is something I've been thinking about lately, though I've never tried it.
Let's say you are building some towers and you place the crossovers in a false bottom in the speaker cabinet. Now you have to run wire up the tower toward the top where the speakers are.
I've seen a type of stiff foam tube that they use to wrap water pipes in to keep water from condensing on the outside or to keep the water inside from freezing. These are available at most hardware, home supply, and lumber stores. They do make them for small pipes as well as large.
So, you do use cable clamps, but you buy them large enough to fit the foam pipe cover, which is slit up the side, and place your wires in them. It should be contained enough to keep the wire quiet even in the areas not constrained by the cable clamps.
Since the foam pipe cover is slit up the side, you can break speaker wires out of the bundle anywhere along it's length.
Hey...it's just a thought.
Steve/bluewizard
Old 12th March 2008, 03:42 PM   #4
Speakerholic
Cal Weldon's Avatar
Yes, that will work just like insulation taped to it but the real issue is to not have the wires traveling from the bottom up to the drivers in the first place as they may come in contact with the magnets or baskets.
Old 12th March 2008, 03:54 PM   #5
Cal: My crossovers will be in the base (false bottom).
Blue: Nice idea, but I am trying to keep the TL cross-section as close to the designer's specification as possible. I doubt that foam is porous???
I am thinking that "glueing" the cable to the side of the cabs with silicone sealer may be the best way for me. I was looking for a neater way though, or maybe some reassurance that cables do not slap against the sides of their cabinets much.
Thank you for your replies so far.
Old 12th March 2008, 04:44 PM   #6
Cal, I'm not sure what you are getting at. You would fasten the 'foam' to the side or to the back corner of the cabinet with cable clamps, that would keep the wire away from everything. Since it has this slit in it, you can break the wires out at precisely the proper height to run directly to the speaker. It is impossible to run a wire to a speaker and avoid magnets completely because (more or less) the magnet is precisely where you are connecting the wire (again, more or less).
The foam tube is closed cell foam but it is still soft and flexible, and I seriously doubt that it's presence would have any acoustical consequences. Though I can see the complications in a transmission line design.
It seems to me a very contained and tidy way of controlling the internal wire in a cabinet. And this wasn't so much a solution for this individual problem, as it is just a good idea in general. It also depends on how many wires you are running.
But again...it was just a thought.
Steve/bluewizard
Old 12th March 2008, 08:07 PM   #7
Speakerholic
Cal Weldon's Avatar
Yes Steve, I am familiar with the product and I agree with you. My point was that if you mount the XO so that the wire movement is not a problem in the first place, you don't have to consider any other sort of treatment. If that's not possible, although I can't see why it wouldn't be, then either of our ideas will work fine.
House of cards in order.
Old 12th March 2008, 09:38 PM   #8
HiFiNutNut is offline HiFiNutNut  Australia
Hi, guys, sorry I am stealing your space for a question on the same track.
How close or far apart should the XO components be placed away from the magnets? I guess for capacitors they are fine but for inductors since they generate magnetic fields would the driver magnets and inductors interfere each other? So how far apart is needed? 150mm? 200mm?
Old 12th March 2008, 09:49 PM   #9
Got it now Cal. I agree, if you mount your crossover on the back of the cabinet, even if it is in a contained box, the wires can run directly to their respective speakers without having to touch anything along the way.
I mounted mine on my removable back, but now wish I had mounted them on the side of the cabinet. When I take the back off, the short wires are alway tugging on the speaker's terminals. If the crossover were on the side. The wire lengths would be fixed and exact, and only the wire to the main input would have had to be long enough to allow the back to be set to the side to work on the speakers.
Still I've seen a lot of projects where the crossovers were hidden in the bottom of the cabinet.
In this person's case, unless I misread, he has a transmission line and that limits the locations where he can place the crossovers and the wires. Not being able to see the actual design, it's hard to make a judgment as to the best method. I can speculate on a few, but they would just be random thoughts, not tried and true solutions.
Still, the original poster seems to have made a decision on the matter.
Steve/bluewizard
Old 12th March 2008, 10:44 PM   #10
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Apart from a blob of silicone or builders' adhesive where a cable runs through an interior panel, I have never fixed any cables internally, and never had a problem with them rattling, despite making some very high SPL boxes. My advice, don't worry about it.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
How do you secure your cables inside your cabs?Hide this!Advertise here!
dynamat for lining inside cabs slr 5000 Multi-Way 2 14th October 2008 11:32 PM
How to secure/fix fragile wires to veroboard? HankMcSpank Everything Else 10 8th July 2008 07:48 PM
Tannoy 15" Reds for sale with crossover and cabs (local pickup for cabs) saletel Swap Meet 0 27th October 2006 10:01 PM
B&W CDM 1 SE - inside cables replacement Alex2 Multi-Way 9 21st April 2004 12:22 PM
Copyright ©1999-2017 diyAudio
