Old 12th March 2008, 12:15 PM   #1
pk is offline pk  Denmark
Default Beyma TD250 horns - How do they sound?
I am looking for a pair of 1" horns for either a B&C DE25 or a BMS 4550 to be used from 1000 Hz (B&C) or maybe 800 Hz (BMS) and up in my home horn rig.
For such application the Beyma TD250 looks great, but I have not heard them. I would very much like to hear from people who have experience with these horns and how they sound - also compared to other 1" alternatives - thanks!
Kind regards
Peter
Old 12th March 2008, 07:32 PM   #2
RobWells's Avatar
I can't be of much help but can say that I own a pair of TD250's, with Beyma 380 cd's driving them.
I have not compared them to other cd's but am very happy with them. I am using them from 3K up with some midhorns / basshorns. I used to use them from 1.2K up with a 10" pro driver for mids. I also used a JBL bullet tweeter with my horns before putting the 250's in instead.
They play clean, are pretty sweet and didn't sound worse than the scanspeak tweeters I used previously. They image nicely too.
Not much help but I don't think you'll be dissappointed with them.
btw I damped them with dynamat type stuff..
Rob.
Old 12th March 2008, 07:39 PM   #3
Hi Rob,
Thanks for your reply! That sounds encouraging!
If I remember correctly, I believe you have had a pair of PD.107 10" mids. Now you are "here", may I ask what you thought of PD's and further: which driver/horn combo have replaced them? Thanks!
Kind regards
Peter
Old 12th March 2008, 07:56 PM   #4
RobWells's Avatar
The PD 107's really were the weak link on those speakers (I used beyma LX60 15's for midbass). They had some pretty bad break up modes that made them sound hard on vocals. In hindsight I should have bought the 10" JBL's I wanted but thought were too pricey.
Right now I'm using Edgars rectangular midhorn with the JBL LE-5 driver. It works a lot better than the PD. Running it 500 - 3K. Using EV15L drivers on 80Hz horn 80 - 500. 2 Labhorns below.
I use a pair of DCX2496's for xo duty, and QSC pro amps for all drivers.
Haven't felt a need to upgrade for quite a while which is encouraging, but I do have a pair of altec 511B's in the garage that need drivers. When I get some spare cash (like that ever happens ) I'd like to try them atop my midbass horns.
Have attatched a measurement of the PD107's (groundplane outdoors 0deg, 30deg, 60deg)
Rob.
Old 12th March 2008, 07:59 PM   #5
Hi Rob,
Thanks a lot for your reply!
Kind regards
Peter
Old 13th March 2008, 04:49 PM   #6
Brett's Avatar
Also consider the 18Sound XT1086 waveguides which are easily available in the EU.
Old 15th March 2008, 03:39 PM   #7
Hi Brett,
Thanks a lot for the suggestion about the 18sound horns. I have heard good things about those too!
Kind regards
Peter
FS: Eighteen Sound XT1086 Cast Aluminum Horns cm7 Swap Meet 0 23rd August 2009 08:37 PM
Eighteen Sound (18 Sound) NSD 1095N Compression Drivers and XT1086 Horns opc Swap Meet 6 1st May 2009 03:48 AM
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 10 27th December 2005 09:10 AM
what do those compromised small bass horns actually sound like? paulspencer Subwoofers 10 27th October 2005 03:21 PM
Horns: Vibrations and resonances in metal horns Rocky Multi-Way 10 28th July 2004 01:38 AM
Page generated in 0.11190 seconds (71.40% PHP - 28.60% MySQL) with 11 queries
