Old 11th March 2008, 03:02 AM   #1
R-Carpenter's Avatar
Send a message via ICQ to R-Carpenter
Default My last bookshelf.
I’ve had this cabinets seating around for a while and now it’s time to put them to the good use.
I’ve been dying to try Hiquphone OW1 and Usher 8945P for a long time. So, I’ve crossed them over at 2200hz with impedance compensations on both (not including picks and port), 4th order L-R. I also ordered extra inductors to play around with BSC later on.
Legs will be made as a cylinders, running along each corner to the top panel and the cabinet will actually be cut in to them.
See what happens.
Oh, and this is definitely the last speaker I am building before I set up Sound easy or Linear X.
Any advantages to Linear X over Sound Easy except lighter valet?
Old 11th March 2008, 03:03 AM   #2
downfiring port
Old 11th March 2008, 03:05 AM   #3
Flared 2 inch port is cut in to the brace as well as in to the bottom panel.
Old 11th March 2008, 03:41 AM   #4
despotic931's Avatar
Send a message via AIM to despotic931
whats the wood veneer?
Old 11th March 2008, 03:42 AM   #5
Burl Walnut left over from the job.
Old 11th March 2008, 03:46 AM   #6
They are beautiful, I love your attention to detail, let us know how they sound when you get them finished!
Old 11th March 2008, 04:12 AM   #7
Thank you. I will.
I am waiting on Madisound to send me caps. Can’t wait to put x-overs together. For now, I a can only circle the drivers and drool over them.
I think I will also experiment with switching between 2nd order and 4th order on the woofer.
Old 17th March 2008, 05:28 PM   #8
John L is offline John L  United States
John L's Avatar
Default Re: My last bookshelf.
Roman, If you mean "wallet", that would definately be one of them. I can't answer for the LEAP folks, but SoundEasy has all sorts of self-help training and tutorials out there. I don't own it, but if I was going to upgrade from BassBox, that would be the one for me.
I'm still trying to fit the down firing port in my mind, and how that will work out. Could you clear it up for me?
Old 18th March 2008, 03:00 AM   #9
Thank you for the correction John.
I was going to make legs this Saturday and just got too busy with the shop work.
Each leg will be a 1.5 diameter cylinder, running along side vertical edges of the speaker cabinet. Probably in Walnut or Mahogany. Each leg will have a rectangular cutout and the cabinet will sort of fit in to it. Lower portion will have a slight taper and merge in with chromed tiptoes. I am also considering a possibility of custom stands. Don’t know every aspect yet, I am designing as I go alone but my guess is that I don’t have to lift up the speaker from the table top or speaker stand a great deal of distance to let the port breath.
I finally got my capacitors and inductors from Madisound today. So, screw the shop work this weekend.
Old 18th March 2008, 03:09 AM   #10
KP11520 is offline KP11520  United States
KP11520's Avatar
Hi Roman,
When will they be done for a demonstration (Broken in)?
I'll come by with my preamp, amp and monitors and do a sound check on a Saturday. Maybe 3/29/08 or is that too soon?
I bet all your work is that beautiful!
Regards//Keith
If Wile E. Coyote had enough money to buy all that ACME ****, why didn't he just buy dinner?
Ultimate <$200 Bookshelf help spots25 Multi-Way 61 20th September 2007 03:24 AM
Bookshelf Speakers Sammich Multi-Way 5 29th June 2007 08:01 AM
best ht bookshelf for me? jp88 Multi-Way 23 15th April 2006 07:19 AM
first bookshelf diy mazurek Multi-Way 4 9th November 2005 01:08 AM
Best bookshelf for $100 each? jaybird Multi-Way 2 9th January 2004 11:38 AM
Page generated in 0.14061 seconds (65.51% PHP - 34.49% MySQL) with 11 queries
