Old 12th March 2008, 08:57 AM   #11
Inductor's Avatar
Default Parts List
2W X-Over VIFA-VIFA
Inductor, thanks for the design help. I'm new to crossover design, so let me see if I got this right. C2, L2, L1, and C3 make up the 2nd order crossover. R2 and R3 are a pad for the tweeter. And C1 and R1 serve as impedance correction. Is that right? How do I now go about calculating the values for all the components for the suggested 2kHz crossover.
Old 15th March 2008, 02:51 PM   #12
Inductor's Avatar
Default 2K2_partslist 1-order
Here you have a very well calibrated design for Hi-Fi use w/ a good step/impulse response from a 1-order xover. Try this and choose the way you like. With this design you can adjust the power for the tweeter on the R2 alone (only one resistor for attenuation). With n/u for the components list, you just have to shunt this connection (i.e. not used). Give some feedback. The other thing is that this is a 1-order (phase is = or less than 90º, so it's very ok. Adjust distances between drivers for this effect. The other thing is that at full power the fs from the tweeter might show a little, but you can also test for moderate output at those frequencies 600-1000/1500 for full posterior operational use at overlap frequencies; xover freq. 2K2 - 89dB band pass, BSC=5dB (+/-) from 1K to 100Hz. Note: it lights up the high frequencies a little bit what some say is natural for an audiophile speaker.
Hope you like.
Old 15th March 2008, 11:55 PM   #13
santiu is offline santiu  United States
Inductor, THANKS for the second crossover option! Between the two designs, which do you think will have a flatter frequency response? Since they'd be used as a studio monitor, flatness is important. In fact I sort of need the opposite of a "Hi-Fi" sound. If anything I'd rather have recessed high's and low's (emphasized mids).
Old 16th March 2008, 12:45 AM   #14
Inductor's Avatar
You can have two external xovers and choose. Pay very much attention with connections. This is only good for you, not for friends or public studio because they might get mistaken very easily. Second order is better for your purpose, good phase and more linear across the spectrum. First order (second xover) is better for classic music, with good impulse response and less components, you can also test this one with a closed box (as for a 35L box or similar), with less bass but well-defined. Note that the first xover might have more neutral bass and highs and a more balanced overlap region because its merging is far better and in a shorter range of frequencies than in a first order, some people might not like that (short overlap region), it all depends. Again, if the first xover is not beaming at xover region 2K5 or 2K6, and it's merging is good then it's ok, if not it's xover frequency has to be lowered to the 2K2 region as the second one is. This does not mean you don't have to test them, because I never did and I don't know how they sound.
Old 16th March 2008, 12:26 PM   #15
Inductor's Avatar
A good reference speaker from Richard Allan.
(more: http://www.ls35a.com/)
http://www.richardallanaudio.com/rallen/frames.htm
go to
Products
Studio Nearfield Monitors
RA8 m
Old 18th March 2008, 09:58 PM   #16
Inductor's Avatar
After you are set with your speakers and your 2.order external xover look at some new Audioquest Single Biwire Speaker - Rocket 33 (ad on Stereophile) cables for the short connections on your mixing table. Double look on your budget...
Budget DIY Studio Monitors RosscoPico Multi-Way 1 20th January 2008 01:11 PM
diy studio monitors brsanko Multi-Way 101 5th December 2007 04:15 AM
ISO: Studio monitors on a budget mazeroth Multi-Way 9 20th September 2005 02:42 AM
FS 604 8G Studio Monitors Thatch_Ear Swap Meet 1 6th August 2002 02:25 AM
Page generated in 0.14590 seconds (54.12% PHP - 45.88% MySQL) with 11 queries
