2 way, front ported, stand mount, HELP
Old 7th March 2008, 11:48 PM   #1
nordhaven is offline nordhaven  United States
Question 2 way, front ported, stand mount, HELP
I'm gonna build a pair of two way stand mounters with front porting. I got the components picked out that I would like to use.
I have been playing around with WinISD and have the box and port basics down. I have the wood working skills, the money and the time. BUT... I am completely lost when it comes to the crossover design!
These are the parts I would like to use.
http://www.partsexpress.com/pe/showd...number=295-374
http://www.partsexpress.com/pe/showd...number=264-835
I am pretty sure I don't want to build crossovers. At least not at this point. Is there a pre built crossover that work well with the parts and style speaker I mentioned? How do I go about finding a complementary crossover for this situation? Thanks for any help!
Old 8th March 2008, 12:08 AM   #2
eastcoast is offline eastcoast  United States
Send a message via ICQ to eastcoast Send a message via AIM to eastcoast Send a message via MSN to eastcoast Send a message via Yahoo to eastcoast
Default Crossover
Your best bet is to invest in an active crossover for the time being, get a Rane 22, they are all over ebay at the moment. Building working passives is time consuming if you don't already knowyour points and slopes.
Old 8th March 2008, 01:06 AM   #3
These are fairly popular DIY drivers. Shouldn't their crossover points be available on the web?
can an active crossover be hooked up externally?
Old 8th March 2008, 09:43 AM   #4
Inductor is offline Inductor  Portugal
Inductor's Avatar
Default Re: 2 way, front ported, stand mount, HELP
Look for a 4/3 Ohms (the one's from PE are all 8ohms) xover, crossing at about 1.800/2.000Hz and being it a 2.order(wo)/2.order(tw), with attenuation on the tweeter about 3/4 dB. You should be fine. Or ask someone to build you one/pair with the specs of the drivers in mind.
http://www.madisound.com/services/leap.php
Old 8th March 2008, 01:33 PM   #5
peter_m is offline peter_m  Canada
Best bet is to ditch the tweeter you chose and have someone else design the x-over.... oh wait looky here: http://htguide.com/forum/showthread.php4?t=13154
This uses a way way better tweeters and way way better x-over then any thing off the shelf. Specially for the RS-180 which is a metal cone. ALL metal cones have a large break-up. That is a frequency at which it tends to ring like a bell and that requires more x-over wizardry to keep it out of hearing range. Off the shelf x-overs are a no no for this type of driver.
You won't regret it!
2 way, front ported, stand mount, HELPHide this!Advertise here!
Want to build a sensitive 2 way stand mount wixy Multi-Way 29 13th November 2007 01:11 AM
Looking for two way stand mount for T27 tweeters fin1bxn Multi-Way 2 11th August 2007 11:49 AM
Stand Mount 2-Way Low Distortion Monitor bssk Multi-Way 2 4th November 2006 01:52 PM
MTM stand mount or floor stand garfieldcat Multi-Way 5 7th July 2004 12:45 AM
Woofer Towers, front-ported or rear-ported? Goldenboy Multi-Way 6 15th June 2004 06:44 PM
Copyright ©1999-2017 diyAudio
