hi everybody, i'm new and i don't know much about desing, and i need an advice.
i've found 2 midwoofers and some tweeters ( 2 philips AD161-T8 and 2 Leea HFD-40 ), and i want to built a 2 way speaker the woofers are similar to the Dayton DC160-8 Impedance: 8 ohms VC diam: 2" Fs: 38 Hz SPL: 87 dB 1W/1m Vas: .95 cu. ft. Qms: 2.8 Qes: .36 Qts: .41 Xmax: 2.5 mm i haven't problems with the desing of the crossovers, but my problem is the cabinet desing wich cabinet you recomend for this speaker?, i'm looking for something with good bass from 50hz, and the size of the cabinet is not a problem. i will use them with a gainclone sorry for my bad english, hope you understand me |
#2 |
sorry, the vc diameter is 1 3/8"
A friend send me this project, it's a bass reflex cabinet, 71 x 18 x 30 cm, about 38 (L), tuning frec: 40Hz port: 3" diam, 6" long. is this ok? |
#3 |
hi
i'm not ok with that box. box volume=26.1 liters fb=37.5 hz vent diameter=5.08 cm vent length=12.72 cm vent area=20.27 or box volume= 20 liters fb=41.83 hz vent diameter=5.08 cm vent length=13.58 cm peak 1.47 db at 70 hz regards |
#4 |
Download WinISD Pro:
http://www.linearteam.dk/default.aspx?pageid=winisdpro It's free, easy to use and you can design your own box....
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#5 |
ok i will try that box.
i have some problems with win isd, i can't create a speaker profile thanks for the replies |
#6 | |
Take your time... (Hi Thawach, I have been looking at your great work around here to, thanks. Nice to have you around. Are you close to were the Ushers are made? eheh, no I meant Taiwan. A late good Welcome...) |
#7 |
to create a speaker profile:
click on New Project, then the 'New' tab....
#8 |
hi inductor
i think that you and PeteMck have the some great work more than that i do. it looks very nice.........as the same. thanks that you talk to me....my friend who your home is far away from me. |
| first amp advice | prezden | Class D | 2 | 18th November 2008 10:05 PM |
| TT advice??? | geordie | Analogue Source | 2 | 30th September 2007 04:04 PM |
| Advice for an amp | wyomoose | Subwoofers | 1 | 12th February 2007 08:07 PM |
| New to DIY, looking for advice | flubhubber | Multi-Way | 1 | 14th November 2005 03:48 PM |
| Poster in Musical Instrument forum needs bridging advice on BrianGT 4780 advice | moving_electron | Chip Amps | 0 | 16th February 2005 12:37 AM |
| Page generated in 0.10093 seconds (70.22% PHP - 29.78% MySQL) with 11 queries |
