#11 |
As a follow up, and using your driver's spec, a sealed enclosure design with a Qtc of 1 would yield a box volume of 1.105 cu ft. with an f3 of 50 Hz. That is without the HR partition. Then you run a sim for the driver in the calculated volume to get the resulting resonant frequency (the peak in the resulting impedance curve). That is the target frequency for the HR to damp. Plan for a partition placement, then calculate Veff. Veff is used to determine the HR port length, tuned to the resultant frequency above. When the HR port is tuned to the box + driver frequency, you will notice a single impedance hump centered at the target frequency, but with a lower Q. Q can be further lowered by damping the port openings. The impedance plot can then be used to estimate the resulting Qtc, which would be by then lowered from the value of 1 that was without the HR. Thanks, Dexter |
#12 |
Hi All,
Sorry for the monologue. If it's OK with you, I will upload my actual enclosure impedance plots (before and after tuning) tomorrow. Please note also that this is not the same as aperiodic design, as aperiodic blindly targets damping (plus it vents outside the enclosure) while the internal HR selectively targets the box resonant frequency. Thanks, Dexter |
#13 |
Thanks, DCRs are something I know little about. Most of my BR experience comes from poor sounding consumer grade stuff.
I also have a pair of SP8Bs rescued from the dumpster, and IIRC that what Augspurger used in his original design. Wish I could find a link to his article. That way I can judge on the merit of the design and not have to blame my math skills Andrew |
#14 | |
The short is No, it is not an EBS and No, 7cuft boxes would be pointless. Open baffle with another driver or subwoofer is likely your best bet. /sreten.
#15 | |
??? You're putting a ~full range driver into a box height better suited for a sub? I designed the TL to put the driver at ~seated ear height. Regardless, TLs benefit from floor loading, though with such a short height I doubt it matters much where you put the terminus short of down-firing. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#16 |
GM
You're absolutely right, that's probably carrying WAF a bit too far. Actually, what you're proposing is a larger scale version of some 1/4 wave pipes I made for the PE 269-469 which I have on either side of my desk as computer monitors. And yes, considering the small footprint and placement close to the rear wall, they won't be nearly as intrusive as the old speakers. Plus it can be done with one sheet of ply. Right on! I'll give it a go. Andrew |
#17 |
Please let us know how they perform as I'm not familiar with this brand and others may be interested too.
GM
| "Good" quality in-ceiling speaker supplier from china | swak | Multi-Way | 0 | 23rd February 2009 07:43 PM |
| 8" stereo ceiling speaker/MP3 boombox | nordhaven | Multi-Way | 3 | 22nd January 2008 09:18 PM |
| $2,000,000.00 ceiling speaker | rcavictim | Multi-Way | 15 | 26th November 2005 02:38 PM |
| in-ceiling speaker recommendations? | deandob | Multi-Way | 4 | 25th September 2003 11:31 AM |
