3-5 mm bitiminous felt  ?
Old 3rd March 2008, 07:21 PM   #11
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
That stuff looks good but it seems rather pricey no?
planet10 needs your help:
Let's help Ruth and Dave
Old 3rd March 2008, 07:57 PM   #12
speakerbug is offline speakerbug  United States
OK - I'll admit I'm a cheapskate, but so are most DIY speaker builders. I have a strong suspicion that there is an equally effective dampening method that won't mailing require $90 to PE.
Old 3rd March 2008, 09:20 PM   #13
Speakerholic
Cal Weldon's Avatar
Peel and stick vinyl floor tiles.
Old 3rd March 2008, 09:47 PM   #14
cixelsid is offline cixelsid  United States
IMO, it's not pricey compared to the brand name stuff..
The killer is the shipping costs given how heavy it is. I wait until PE has one of their free shipping deals then order what I need.
Old 3rd March 2008, 11:46 PM   #15
BlueWizard is offline BlueWizard  United States
First, I'm not real eager to put anything in my speakers with 'bitumen' in the name, which basically mean tar or asphalt.
I think a dense carpet (felt or foam) underlayment would work just as well, with no potential for becoming an environmental disaster area (he said somewhat sarcastically).
As for vinyl tiles, I think they are too dense and smooth to be effective - that's just me.
Personally, I've always used fiberglass, though if I were to use it now, I would put down the fiberglass and cover it with a thin layer of polyester batting.
Also, keep in mind that there is a new product on the market. It is flame retardant cotton house insulation that is made primarily from recycled fiber and comes in rolls just like fiberglass. It's called 'Ultra Touch' -
http://www.ultratouch.net/
Again - this is just me - I don't feel real comfortable putting petroleum impregnated fibers in my speakers. There are just too many other fibers and foams to not use them.
Steve/bluewizard
Old 4th March 2008, 04:33 AM   #16
Speakerholic
Cal Weldon's Avatar
The tiles do not take the place of the fiberglass, they damp the panels. Think of it as two stage process.
Old 5th March 2008, 03:10 PM   #17
By 'damp the panels' I assume you mean prevent the side and back panels from vibrating rather than prevent reflected waves inside the cabinet.
Still, I don't see how vinyl tile can accomplish either of those things. Wouldn't some serious bracing do a better job on the sides and back, then use 'soft' damping to prevent reflected waves.
Actually, just curious about what you mean by 'damp the panels'.
If you mean to isolate the inside from the outside, as in sound proofing, which in turn is really just preventing the cabinet itself from vibrating. I would think some dense carpet padding foam glued to the sides and back, then covered with a fair layer of Poly would get the job done.
In my mind, I can picture tar impregnated felt doing an excellent job of preventing the escape of internal vibration. It would seem to have both energy absorbing mass as well as sound absorbing qualities, but neither changes the fact that you are putting a petroleum product in your speaker cabinets.
Though I confess I may have a misunderstanding of what 'bituminous felt' actually is. Based in my understanding, I would want something a little less toxic for my speakers.
Just curious.
Steve/bluewizard
Old 5th March 2008, 04:25 PM   #18
R.I.P.
I have used self adhesive vinyl floor tiles for damping panel resonances
and they are very effective - as long as you have the solid vinyl types -
not the foam with vinyl surface layer types.
The mass + viscoelasticity wall damping appraoch is to drop thin
wall panel resonances below the critical midrange frequencies
and to damp (via hysteresis) the Q of the lowered resonances,
an approach typified by the UK BBC and the material used was
bitumen impregnated felt panels, still used by Harbeth.
The main effect of adding panel damping to most thick wall speakers
is to moderate the Q if the main high Q panel resonances, it does not
remove them. It will lower frequencies, lower overall flexure due to
mass but resonances will remain, thewy are not completely damped.
It suits thin walls best and is restrained layer damping.
For thicker walls constrained layer damping is better, this can be
achieved by laminating two layers with a suitable constrained
layer between them, but good info on this is hard to find.
/sreten.
edit :
All carpet damping stuff I've seen is not heavy enough or lossy
(i.e. its too bouncy/elastic) enough to be particularly effective,
though its better than no lining at all.
Old 5th March 2008, 06:19 PM   #19
Default Wow - too much information
OK. Thanks.
What would you use if you were building these? Can you recommend an alternative to the 3 - 5 mm bitiminous felt? Even the #90 "tar paper" stuff I looked seemed barely 2 mm. The walls in the speaker are 18 - 25 mm and I plan on putting additional poly batting stuff over the first layer of dampening.
I was hoping to avoid paying for dynamat or similar product, but I don't want to mess it up at this point
Old 6th March 2008, 03:20 PM   #20
I guess it depends on what your goal is. The speakers you are looking at are (1020mm) 40" high and (225mm) 8.86" square on the ends. The drawing shows one cross-section brace. The cabinet is for a 6" woofer with a rear port.
If you are building this out of cardboard, the you are most certainly going to need to 'damp the panels'. However, if you are building it with the side of 1" MDF and the fronts and backs out of 3/4" MDF as specified, I don't think the problem is going to be as great.
If you can find 1" MDF, build it all out of that, and adjust your dimensions accordingly. If you are concerned, add another brace.
Now line the walls with some type of 'fluffy' material. You can use house insulation (3" to 4") and over that with a thin layer of Poly batting.
If you insist on some heavy dense material on the wall, I've seen roles of recycled rubber mat about 1/4" to 3/8" thick that are at the same time soft to walk on, but still hard and dense. Glue this to the walls. (saw this at Menards home building supply store).
I've also seen roles of thin soft rubber mat to be used as carpet underlayment. I'm guessing the thickness was about 1/16" though it may have been slightly thicker. You can build up layers of this. I saw this at Fleet Farm Supply in the carpet section.
You can try Sreten's idea of solid vinyl floor tile, but I don't personally see that it really buys you anything. If the walls/panel are flimsy, then a floor tile isn't going to matter, and if the walls/panels are thick, solid, and braced, I still don't see how tile helps.
As to the bitiminous felt, if you must, then find a thick dense layer of felt, but skip the bitiminous part.
Also consider, soft foam or convoluted foam, you can even use that in combination with Poly batting.
Here is a link to the cheapest convoluted foam I've found anywhere.
http://www.uline.com/Browse_Listing_...uted+Foam+Sets
http://www.uline.com/Browse_Listing_...?keywords=foam
But if you want to 'damp the panels' I would suggest just doing a better job of bracing them.
Hey...it's just one man's opinion.
Steve/bluewizard
3-5 mm bitiminous felt  ?Hide this!Advertise here!
felt vs foam around tweeter dsrviola Multi-Way 11 7th February 2010 09:09 PM
felt pads behind driver? marc rosen Full Range 0 17th May 2009 07:51 AM
Purpose of felt lining in TL ? dublin78 Multi-Way 1 28th February 2008 10:33 AM
Felt metal? Baki Multi-Way 5 2nd February 2005 04:46 AM
felt on baffle zach Multi-Way 11 31st January 2003 10:27 PM
Copyright ©1999-2017 diyAudio
