Old 4th March 2008, 02:40 AM   #11
cuibono is offline cuibono  United States
cuibono's Avatar
nice diagram! I wouldn't redo that joint, it looks pretty solid with the wires wrapped together like that.
Old 4th March 2008, 05:01 AM   #12
Try solder lug terminals. They were used during the days of point to point wiring...prior to PCB's.
Ray
Non Illegitimus Carborundum
Old 4th March 2008, 03:39 PM   #13
Andersonix's Avatar
In addition to the advice already given, I would strip the insulation back far enough so it doesn't melt and contaminate your joint. You could also use some heat shrink sleeving to cover up some of that blob and add an extra level of clamping if things go wrong.
Question about soldering the balanced interconnect cable rnzr Analog Line Level 7 19th September 2006 01:24 PM
Question about Soldering Temperatures KT Chip Amps 6 8th June 2004 11:07 PM
Crossover soldering question Phatman91624 Multi-Way 6 19th July 2003 06:03 PM
more soldering help please theChris Equipment & Tools 22 5th June 2003 04:07 PM
Soldering to-363 PCP Solid State 1 18th January 2003 12:30 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
