What are some common ways to do this? And does anyone have a picture of a recessed hex socket cap screw they can show me?
Thanks, Brendan |
#2 |
diyAudio Moderator Emeritus
This is how I mounted the baffle for my subs.
Rodd Yamashita |
#3 |
One online source for threaded inserts is here -
(with pictures) http://www.mcfeelys.com/threaded-inserts |
#4 |
Flat head: http://www.instockfasteners.com/PROD...cketscrews.asp
Drill size/counterbore: http://www.csgnetwork.com/screwsochdcaptable.html GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#5 |
One of the problems I've seen about using socket head cap screws on wood is the it requires a bit of care when making the counter bore and you will need the right bit and a decent drill press to get a good counter bore. Than you will also need to make the counter bore large enough to accept a decent sized washer to spread the load that can be applied by a machine screw (socket head cap screw). If your not careful you can easily compress the wood making the bolt seat troublesome and prone to loosening in time. In my sub baffles above, I used large diameter fender washers and locktite on the threads in an attempt to over torquing the bolt and compressing the wood.
Rodd Yamashita |
| Cabinet w/Hardwood front baffle | caz | Multi-Way | 4 | 12th July 2009 12:04 AM |
| Baffle width and cabinet depth | Lewis Moon | Multi-Way | 1 | 5th October 2008 06:12 PM |
| attaching drivers to baffle | big314mp | Multi-Way | 5 | 18th January 2008 11:38 AM |
| Ideas on how to make front baffle removable? | tf1216 | Multi-Way | 11 | 3rd April 2006 04:53 PM |
| Removable TO-220 - Sockets | Super_BQ | Pass Labs | 8 | 30th November 2003 09:46 PM |
| Page generated in 0.08252 seconds (73.97% PHP - 26.03% MySQL) with 11 queries |
