Don't light that cigar just yet.
Even though WinISD has the driver listed, it seems to have too few params to calc the port dimensions.
I transferred the params to LspCAD but as per usual, it says "too few parameters defined". Even using the crosscalc feature doesn't help.
Anyone know how to work out the qes/qms from the given data, which is, at the bare minimum, what WinISD needs. I just need a good working box volume and port data.
Thanks.
Thanks.
me too! need peerless driver specs
I have some 6 1/2 inch peerless drivers that look just like the 8 inchers on this post
the numbers on the back are
QC 910304
Cat no 031732
I have emailed Peerless and got no reply.
Where should I look?
They are brand new and I would really like to use them.
Nicholas@mindspring.com
QC 910304
Cat no 031732
Re: me too! need peerless driver specs
Sure that's not 831732 , in which case
Fs = 40
Qms = 1.7
Vas = 24L
xmax = 5.5
Sd = 130cm2
Qes =.47
Re = 6 ohms
Le = .5mH
Z = 8 ohms
Pe = 90w
heretohelp said:
QC 910304
Cat no 031732
Fs = 40
Qms = 1.7
Vas = 24L
xmax = 5.5
Sd = 130cm2
Qes =.47
Re = 6 ohms
Le = .5mH
Z = 8 ohms
Pe = 90w
- Request: Peerless driver specs
