Starting to plan out a pair of Massive Line Arrays (MLA)...
Old 2nd March 2008, 12:38 PM   #31
afoelges is offline afoelges  Norway
Nice project! And somewhat challenging as well, given your budget constraints. Some comments:
1) Given that you will use the DCX2496 as an active x-over I would not bother with impedance-flattening. As long as you take the time to measure the response of your implementation any deviations due to changes in impedance can easily be corrected with the EQ of the DCX. This will also keep passive components out of the path of these drivers, bettering amp control over them. And, at least if fed by a 24/96 source (using the SRC2496 as a frontend will achieve this) the DCX is highly transparent even at quite high levels of EQ'ing.
2) Although the M130 and PT2 combination should work well, you should try to avoid cutting the length of the lines from your suggestion of (at least) 12 + 8 per channel. To achieve line source behavior at lower frequencies (which you will want) your woofer-line should cover about 70% of the floor-ceiling distance if possible. Also, experience seems to indicate that using tweeter-lines of about the same length as the woofer-line leads to a more 'right' sounding array (probably due to a better balance in frequency response between direct and in-direct radiation).
3) The center channel is tricky, and you may be better off leaving that for later. This is because: a) Going with PT2 mounted horizontally you will want a line that is at least as wide as the width of seating for viewers = a very large center, b) Mounting it vertically you can only use 1 tweeter (which, in the case of the PT2 will have to be crossed quite high to keep up in terms of demanded SPL), more than that will get you in serious trouble in terms of cancellations at certain frequencies, and c) You may not need one as the sweet-spot of the arrays will be a lot larger than what you are used to. This is particularly true if you angle them quite aggressively (crossing in front of listening position could work out well) as this will better balance the relative SPL of the two speakers when you move to the side.
Any way - good luck with the project! Although there are some challenges to overcome I think the end-result can turn out great!
-A
Old 2nd March 2008, 04:04 PM   #32
Wavebourn is offline Wavebourn  United States
Wavebourn's Avatar
Originally posted by ShinOBIWAN
The argument is that if you sit in the sweet spot whilst watching a movie and you also have mains that image well, then they should be able to throw a phantom image using the mono centre channel signal.
If these conditions are met, then its possible you could omit the centre and maybe even have a better system for it, the front sound stage would certainly be consistent.
Believe me, with good line arrays these conditions are met always, i.e. "sweet spot" is everywhere in the listening room.
The Devil is not so terrible as his math model is!
Old 2nd March 2008, 04:06 PM   #33
Wavebourn's Avatar
Originally posted by chops
Stereo imaging has nothing to do with needing a center channel or not. A center channel is required regardless of the quality of the main channels for proper dialog playback in movies.
Side and back surrounds are not an "initial idea" that will eventually fail either. They are required for proper playback of movies. Again, they have absolutely nothing to do with the quality of the main channels.
Besides, I have already answered my own center channel question in my previous post above.
It is your beliefs VS my experience. Good luck!
Old 2nd March 2008, 04:33 PM   #34
chops is offline chops  United States
chops's Avatar
Right back at you...
Charles
Old 2nd March 2008, 05:32 PM   #35
Wavebourn's Avatar
I tried to share my experience to save you time and money. I built several models of line arrays, both for music / home theaters and for concerts.
Old 2nd March 2008, 05:40 PM   #36
despotic931 is offline despotic931  United States
despotic931's Avatar
Send a message via AIM to despotic931
Default Re: rest of setup
Originally posted by auplater
http://www.diyaudio.com/forums/showt...603&highlight=
C-T-C @ 5 1/2" will be asmaller issue at 2 Khz for sure... it's just whether or not you'll hear the lobing. It will definitely be an improvement over the 6 1/2" 'ers, though. wavelength @ 2100 Hz ~ 6.5", and ideally you'd like to keep the ctc distance well below that... to minimize irregular response... that's the problem
Jim Griffin's paper on the subject...
http://www.audiodiycentral.com/resource/pdf/nflawp.pdf
John L.
nothing is big enough and you don't have enough stuff, obviously you need a new larger project my friend! hehe
Old 2nd March 2008, 11:40 PM   #37
gtforme00 is offline gtforme00  United States
gtforme00's Avatar
Chops,
I've kept an eye on your thread from the start but didn't want to try to sway you from the Dayton 6.5s since you seemed to like them so much. Now that you are looking to other options and smaller woofers, I think you should look at the drivers here.
Particularly, look at the 5.25" peerless woofers.
Similar specs to the M-130, but not quite as much x-max. Has the advantage of shorting rings and probably lower distortion over the M-130. It was crossed over to at 2.5kHz in the NHT speakers it was used in, so it should be easy enough to cross over.
The best advantage it has is price, 10 bucks apiece for what would have been a $40 woofer. If I were building a line array (wish I could right now, I'd love to try one) those are the woofers I would use.
Good luck with the project!
David
Old 3rd March 2008, 05:04 AM   #38
chops's Avatar
Hey David, thanks for the info. However, I think I have been talked into upgrading even higher and going with the M-130X drivers!
There's no doubt I'm going to be putting some major cash into this project, and at this point I am willing to do so as long as the money is there to allow me. If the few things I have up for sale actually sell, then I should be fine with funds for the project.
If things go south as far as the sale items are concerned, I'll definately look into the drivers you mentioned. In fact, I saved the link to that page you linked to!
Again, thanks!
Charles
Old 17th March 2008, 02:34 PM   #39
Bluto is offline Bluto  United States
Default Chops & AJ
Kinda disappointed you didn't stay with Dayton idea, I was even going to suggest a cheaper tweeter, I liked the whole concept.
AJ - Can you tell us about your bass unit? Looks interesting.
Bluto
Starting to plan out a pair of Massive Line Arrays (MLA)...Hide this!Advertise here!
NSB line arrays for PA use? Spasticteapot PA Systems 1 1st April 2007 12:32 PM
Do line arrays... LizardBrain Full Range 4 23rd March 2006 05:21 AM
WTB: Pair of line arrays mazeroth Swap Meet 1 15th March 2005 02:03 PM
Line Arrays Down Under deaf monkey Multi-Way 0 14th December 2004 06:03 PM
Line Arrays Won Multi-Way 33 10th February 2002 10:20 PM
Copyright ©1999-2017 diyAudio
