I will post plots later when I finally get them off my other computer.
I recently finished my prototype open-baffle center channel speaker. It ended up being a three way using Dayton RS 8" woofers, Neo3 PDR dipole tweeter, and 3" Tangband bamboo midranges. Crossover points are 500Hz and 3.5kHz, 2nd and 4th order L-R acoustic slopes. The ONLY thing I don't like about the finished design is two low points in the impedance plot at 1kHz and 8kHz. With the exception of crossover point peaks, the average is around 4 Ohms, which was the target. Those two aforementioned dips go down to 2.5 and 2.2 Ohms, respectively. It is a pretty steep dip, it doesn't linger down there. My first thought is panic and redesign the crossover so I don't cook my amp. But then I'm thinking because it's at higher frequencies, even a low impedance won't demand a lot of current (and it's the current and heat that kills the amps) Any advice on this? Am I being too paranoid? Ideas to fix it? Would a Zobel on the woofers or mids help? Thanks, Anthony |
#2 |
Here's the impedance plot in question:
#3 |
Hi Anthony,
Can you please post the XO schematic too. Thanks, David. |
#4 |
I will have to check the actual values, as some of those were tweaked a bit to coincide with what I had available, but for the most part I stayed pretty close.
Thanks for the help. |
#6 |
Outlaw 1050 or 955, I believe. 5 channel and has run flat 4 Ohm magnepans for years without breaking a sweat.
#7 |
I've been studying this for a while today, the only thing I can think of is that I wired the Mid low-pass ahead of the Mid high-pass.
In a band-pass filter, does it matter what order you put the elements in? I thought the resonances being so far apart would mean it would not matter. If it does make a difference, could I just switch them, or would I have to redesign since it would mess up both sides of the crossover? |
#8 |
Well, I'll be the first to admit, I'm over my head here, but I would be curious to see the frequency response graphs. I think that would give the Impedance graphs more perspective.
Also, the precise model numbers of the speakers would help. At best I'll be an observer, but I'll probably learn a bunch. steve/bluewizard |
#9 |
Sure thing, here's the REW measurement (non-gated, in room). 2m, on axis (blue), 30 degree off axis (red). BTW, 30 degrees puts this well outside the seats of my HT.
There's a room anomaly at 200 Hz. It shows up on measurements of my Magnepans as well. |
#10 |
I not this isn't exactly what you are after.... but I presume you are paralleling the RS180's and TB3s. You might need to use series connections and a new crossover.
| Impedance rate VS impedance stability | TomatoBangBang | Tubes / Valves | 6 | 4th September 2008 10:46 PM |
| Need help understanding transformer impedance ratios and impedance matching | percy | Tubes / Valves | 5 | 28th February 2005 08:35 PM |
| Ideas for sub(s).. | DigitalJunkie | Subwoofers | 5 | 24th January 2005 04:43 AM |
| I Need some sub ideas... | eRiCdWoNg | Subwoofers | 8 | 23rd October 2004 12:02 AM |
| Page generated in 0.16152 seconds (52.56% PHP - 47.44% MySQL) with 11 queries |
