Tang Band W5-704D + Dayton PT2C - Page 2 - diyAudio
Old 25th February 2008, 11:14 PM   #11
Jay_WJ is offline Jay_WJ  United States
Of course, there should be some difference in power handling if you compared 40 Hz Fb in 20 liters to 50 Hz Fb in 14 liters. But as your sim shows, in this case, there should also be a significant difference in the bass rolloff. Depending on the speaker placement, 50 Hz Fb in a 14 liter box can sound boomy due to the midbass peak. Using a Zobel circuit and a lower DCR iron core will mitigate the problem a bit. My sim assumed .4 ohm series resistance and Zaph's T/S measurements were used.
Old 26th February 2008, 11:45 AM   #12
Send a message via AIM to 69stingray Send a message via MSN to 69stingray Send a message via Yahoo to 69stingray
So that's the big dilemma 69stingray
Yup. No HT or loud orchestras passages Bedroom bookshelf speaker. They will be on a bureau, right up against a wall.
Thanks for all of the options, I will have to ponder this some more.
In regards o BSC, I was thinking 3 dB, but since they will be sitting on a bureaus, next to a wall, would no BSC be appropriate?
Audio DIY Page
FOLLOWMY529.COM - Subscribe and follow the performance of my daughter's 529 College Saving Account.
Old 4th March 2008, 02:23 PM   #13
diyAudio Member RIP
According to Zaph no BSC is hardely ever appropriate, usually this
means corner or corner & ceiling placement and you have thrown
away most of the the ability for the speaker to sound good.
Zaph's reduced BSC versions do not reduce it by much.
Also FWIW I'd say maximum tuning frequency of a vented box should
be around 44Hz, bottom E on a bass, but the lower the better IMO,
around 31Hz, bottom B on a piano is preferable, if possible IMO.
Another FWIW is that Vas is a small signal phenomena and for large
signals it is anything but linear, causing odd harmonic distortion, any
assymetry causes even harmonic distortion. There are other issues
e.g. voice coil offset etc. to also consider......
Conversely the air in the box is comparatively extremely linear and
the more this dominates the more linear the speaker is by default.
A 15L vented box should have a suitable driver with a Vas of around
30L for clean bass, such a driver (usually 6.5") will be far superior
in the bass end than a lower Vas driver, for the reasons given.
Vas = 12L and Qts = 0.45 is more workable than 8L and 0.6.
Fs ? lower due to higher Vas ? guesstimate = 45Hz.
for 15L best tuning frequency = 33Hz IM0, max IM0 37Hz.
(Using WinISDbeta, not as accurate as Unibox)
/sreten.
Tang Band W3-593SF vs. Tang Band W3-926SD Zaputh Full Range 17 5th June 2009 11:37 PM
Tang Band W5-704D 5-1/4" Woofer-- has anybody used this? loninappleton Multi-Way 32 30th July 2008 05:35 PM
Tang Band W5-704D revelator Full Range 0 1st February 2008 06:26 AM
Dayton RSS265HF-4 vs Tang Band WT-1427B jetty2 Subwoofers 1 6th August 2007 01:55 PM
8 x 12 Tang Band troystg Subwoofers 3 2nd February 2007 03:37 AM
Copyright 1999-2017 diyAudio
