Old 16th February 2010, 06:25 AM   #131
40 watt is offline 40 watt  Canada
Default Paid...
John, ya's got doolars...I think some green ether went your way...if the process went well. Paypal has "completed" status in my account re: invoice.
I hope the process worked...
Old 16th February 2010, 06:25 AM   #132
Default If one left, I would like to get it
Hi MJL21193,
If you have one left, I will take it (gladly)
Cheers
Peter
Old 17th February 2010, 01:38 AM   #133
MJL21193's Avatar
Got it, thanks
Originally Posted by peterhenk View Post
Hi MJL21193,
All out for now Peter but more soon. Send me a PM if you are still interested.
Old 18th February 2010, 02:20 AM   #134
MJL21193's Avatar
I should have some new boards by early next week for the jig. Please PM me if you are interested.
Also I have had several inquiries about the microphone posted earlier and would like to see if there is any interest in this as a kit also:
It uses the WM-61A capsule and has a built in battery powered preamp. It is perfect for the speaker testing jig - just plug it in and turn it on.
Post you thoughts here.
I will be ordering a limited number of PC boards for these to start. I will post back here with pricing as soon as I have that pinned down.
Old 18th February 2010, 02:25 AM   #135
Attachment 158637
Attachment 158638
Count me in... I like...perfect mate for jig.
Old 18th February 2010, 04:33 AM   #136
anatech is offline anatech  Canada
anatech's Avatar
Hi John,
Any idea what the cost will come in at? It does look like a nice project.
You do such a good job at packaging, impressive.
-Chris
"Just because you can, doesn't mean you should" © my Wife
Old 18th February 2010, 04:37 AM   #137
critofur's Avatar
Send a message via AIM to critofur Send a message via MSN to critofur Send a message via Yahoo to critofur
PM me - there is still one that is on the fence.
PM sent
Regarding the mic kit - can you test capsules vs a calibrated mic or such?
I've built a few DIY mics with Panasonic capsules - I just use them without power or pre-amp straight to my sound card. Works OK, maybe greater dynamic range with the power/preamp setup?
It'd be awesome if we had some way of having (at least close to) calibrated mics for cheaper. I've got a few mics, none calibrated.
The only way I see that happening is if we find that a certain "batch" of WM61A capsules are all pretty close, so just one needs to be calibrated and then if we buy the kit, we can all use the same cal file with decent results?
Critofur
http://www.ohmspeakers.com <- all the folks here are my friends
Old 18th February 2010, 06:48 AM   #138
bbe is offline bbe  Sweden
bbe's Avatar
Count me in...
Old 18th February 2010, 10:55 PM   #139
MJL21193's Avatar
First, all kits were shipped today. Let me know when you get them.
Originally Posted by anatech View Post
Hi John,
Hi Chris,
I'm working on it - I need to come up with an easier way to make the case. The original is wood, which is fine for a prototype by doesn't fit for making multiples - it would be too expensive.
Originally Posted by critofur View Post
PM sent
I don't think calibration is really needed for the DIY use of a measurement mic. There is a generic cal file available for the WM-61A capsule that flattens the HF response. The WM-61 is very linear in anyway.
SPL accuracy is not really critical, you want to be able to measure each drivers output relative to the other drivers and measure each speakers output relative to the other speaker.
If calibration is something you feel you need, the mic/preamp unit can be sent out for calibration, just like any other mic. The calibration comes in the form of a file they you input to the measurement software you're using (like Speaker Workshop or HOLMImpulse).
Old 19th February 2010, 01:44 AM   #140
MJL21193's Avatar
Originally Posted by bbe View Post
Count me in...
Ok, some interest but not as much as I expected. It would be nice to see a few more hands...
I'm not sure just how good the mic input on a soundcard is - they are not supposed to be very good but it is probably good enough for speaker testing. I've never tried to use one for that before.
The preamp I have in this microphone is VERY good though and has a couple of handy features for measurement. First it is ultra portable - it is a self contained mic with preamp. Heck, when you are done measuring you can even do some Karaoke with it, just plug it in to any amp and sing along...
It has 2 gain settings, 20db and 10db for nearfield measurements. It's ultra low noise, battery powered with regulated phantom power for the electret capsule. Low current drain, a 9V battery will last a loooong time.
Enough pitch, I will order a few boards, see what I can scheme up for the case and ask again if there is any serious interest in this unit.
I can say that it has made these kind of measurements very convenient for me, I won't look back.
Speaker Testing Jig Assembly Thread MJL21193 Construction Tips 58 16th January 2013 12:04 AM
Wallin Jig v2 for Speaker Workshop 454Casull Multi-Way 11 20th March 2009 02:56 AM
FS: DIY Wallin Jig II for Speaker Workshop honinbou Swap Meet 8 27th May 2007 06:46 AM
Speaker workshop Wallin jig setup for sale kingdaddy Swap Meet 0 7th December 2005 05:05 PM
Wallin Jig 1 for Speaker Workshop: Wiring Problem?! Rarkov Multi-Way 1 12th September 2002 08:18 PM
Copyright ©1999-2013 diyAudio
