Old 28th February 2003, 10:50 PM   #1
Kanga is offline Kanga  Australia
Default Plinth design for comment
Hi all
I'm getting close to finishing the veneering on my bass speaker boxes and its time to make some plinths for them to sit on. Following on from a previous thread about plinths where someone suggested using a sand box , I thought about a design as shown in the attachment.
I want to keep the plinth no wider than the speaker, because I think that this looks better. I have suspended wooden floors, so the idea of the design is to absorb vibrations in the sand, which effectively forms the connection between the speaker box (which is 25mm MDF) and the base of the plinth, which sits on the floor, maybe with spikes or bluetak.
One potential problem is that if the speaker is bumped from the side then it may kick over a bit. Hopefully it wouldn't fall if the sliding joint is tight enough, however I could always put some pins through from the side across the sliding joint and into a clearance hole. It wouldn't touch in normal operation but would stop it from falling over.
Any comments on this design from the knowledgable and helpful bods out there?
Mick
Old 2nd March 2003, 12:49 PM   #2
RobWells's Avatar
Hi Mick,
I like your idea, however I think the "sliding joint" would short-circuit the isolation, and that you'd be better with a gap all round .ie have only sand between the speaker and the plinth.
Cheers
Rob
Old 2nd March 2003, 01:03 PM   #3
RobWells's Avatar
How about this: ?
Rob
Old 3rd March 2003, 01:11 AM   #4
How about sandwiching a mousepad between the bottom of the speaker and a base plate. Use a flexible adhesive and should work pretty well.
Pete
Old 3rd March 2003, 08:57 AM   #5
Thanks for your replies Pete and Rob
You might be right about the sliding joint Rob. In theory it should be OK, but in practice it may end up binding up. With my enclosure design I need a piece that attaches to the base part (item 1 in the attachment), as the base is removable for access into the bottom part of the speaker. By attaching it to another piece (item2) I can screw the whole lot to the bottom of the speaker walls.
I like your idea with the spikes, but I'm wondering if I could achieve something similar by just widening the gap in the sliding joint. The difference would be the lack of the silicone sealant and also the lack of the spikes. I don't really understand spikes enough to know how they would contribute acoustically in this situation. The attachment shows another design.
Pete - have you tried the mouse pad? Is it acoustically isolating across a wide frequency range?
Mick
Old 3rd March 2003, 07:32 PM   #6
RobWells's Avatar
Hi Mick,
The sealent I suggested was just to keep the wood in place (so it doesn't move and touch any sides. I thought the spikes were meant to minimise contact between 2 surfaces, and thus lower transmitted vibrations - I'm sure someone here can give a proper scientific explanation.
What about using a slab of concrete that your "bit that screws in the seaker" can slot over (push fit) that is high enough to keep it off the bottom plate. You could glue the concrete to the bottom plate, pretty much like your second drawing except there will be air instead of sand down the thin gap at the sides.
If that didn't make any sense I'll mess another of your drawings up in mspaint.
cheers
Rob
Old 3rd March 2003, 10:52 PM   #7
Keld is offline Keld  Sweden
Keld's Avatar
Pete
Hi
I have tried the mousepad thing (several layers), it was very "springy" and the sub was rocking, now I have thick felt under and thats much better.
Keld
Old 4th March 2003, 09:43 AM   #8
Thanks for your ideas Rob and Keld
Rob
I didn't quite follow your idea. Any chance of a diagram?
I thought that spikes may increase vibration transmission, but I'm not sure how.
There are two conflicting aims here. One is to disipate vibrational energy away from the speaker walls, which are excited by the driver. The other is not to excite the floor, which can also produce sound when excited. So by coupling the speaker well to the floor, the problem may be transferred from the cabinet to the floor. My design was aiming to use the sand to dampen/absorb vibrational energy transmission from the speakers. Using a concrete slab, as you suggested, would further help by absorbing vibrational energy but produce low vibration amplitude due to its high mass to area ratio.
Any other thoughts?
Mick
Old 4th March 2003, 05:17 PM   #9
RobWells's Avatar
Hi Mick,
Here ya go:
Rob
Old 4th March 2003, 06:50 PM   #10
RobWells's Avatar
Hey Mick - did you read the isolation post started by Peter Daniel in "everything else" ?
I've just read through it all and am totally confused now
Hopefully some of the people involved will help you more than I can..
Rob
Is this a good idea for a plinth design? wixy Analogue Source 2 15th November 2007 10:58 AM
Plinth Design dude007 Analogue Source 10 1st August 2007 05:26 PM
Comment on my DIY Sub Design htgeek Subwoofers 22 8th April 2005 05:26 AM
Please comment this design promise Solid State 0 20th January 2005 05:25 AM
comment on this design, please. JAZZ2250 Tubes / Valves 6 24th November 2002 10:45 PM
Page generated in 0.12526 seconds (79.13% PHP - 20.87% MySQL) with 11 queries
