speaker wattages - Page 2 - diyAudio
Old 22nd February 2008, 10:26 AM   #11
Moondog55's Avatar
Check out Rod Elliot
http://sound.westhost.com/index2.html
I think his thoughts are valid, the equal power point being 350 Hz, and my limited experience says that the wider the spread of the midrange the better the overall sound.
I would favour a much lower X-O, a full octave lower at 250, and bi-amping I generally use 120/150 Hz.
This is expensive when using passive .
i have always thought that commercial speakers used higher X-O points merely to save money on copper in the inductors.
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 22nd February 2008, 03:06 PM   #12
Rarely in a bass/mid/high or bass/high speaker system do you ever see a crossover below 500hz.
However, we also see many modern speakers that crossover in the 150 to 350hz range. That is because those speaker are not standard bass/mid/high configurations. They are typically sub-bass, bass/mid, high configurations.
The existence of external subwoofers, has lead people to the idea that the can build sub-bass into a single cabinet multi-speaker system.
Just an additional thought.
Steve/bluewizard
Old 4th March 2008, 03:47 PM   #13
Originally posted by pigophone
Thanks for all the help guys!
So according to Blue Wizard's graph, a the woofer to mid crossover should be around 500
hertz to allow the woofer to take that huge wattage load that occurs from 250 to 500 hertz?
Hi, No.
Linear power scales are very misleading. Scaling to dB completely
removes the "huge wattage load" and more to the point the graph
shows peak levels, i.e. clipping levels, not average rms power levels.
/sreten.
Bridged LM4766 resistor wattages ballsingtripp Chip Amps 18 12th March 2009 08:22 AM
dimentions of speaker box in speaker spec sheet? Dan2 Car Audio 2 6th February 2009 06:34 AM
Mixing max wattages pityocamptes Car Audio 4 2nd October 2007 09:24 PM
New Ribbon Speaker Technology - Approach the perfect speaker? cocolino Planars & Exotics 49 16th January 2005 11:12 PM
Wattages & Loudness: ?I'm Lost? edsmith Tubes / Valves 7 12th August 2004 08:24 PM
Copyright 1999-2017 diyAudio
