#101 |
frugal-phile(tm)
Perhaps a bit misleading without the conditions.
A tightly coupled isobarik woofer has 1/2 Vas, same Fs, same Qt, 2x mass and BL vrs a single one of the woofers. So (ignoring the volume of the isobarik chamber) if you put a compund driver in a box volume V, it has the same response as a single driver in a box of 2*V volume. So isobarik simply lets you use a box half as big (+ chamber) as you would need for a single woofer. 4 drivers (2 isobarik pairs) can be put in the volume you would use for 1. Putting
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#102 |
diyAudio Chief Moderator
You are right. I had in memory something about targeting the same volume and using it for going lower scenario or I dug it up from simple mass loading. Ignore my earlier post. Bad memory. Compound just allows half a box is a straight rule.
#103 |
But you also reduce the work load on the drivers by half, as well as lessen harmonic distortion, especially if one of the drivers is physically inverted from the other.
Charles |
#104 |
Of course. Those are quality gains to consider as positives. Still there is a 3dbW loss in sensitivity that demands horsepower. The good thing is there are affordable high SPL pro woofers around that were not the norm in the 80s when some companies like Linn used the principle, plus class D. So this Isobarik thing becomes very viable again IMHO.
#105 | |
Charles |
#106 |
Will save much space, braces the cabinet, push pull back magnet linked anti resonance trick, not a bad dish.
#107 | |
I'm curious to see how the distortion actually changes.
Building a 2.1 system out of a 3/4"x4'x8' sheet |
| RFT Loudspeakers | argonrepublic | Multi-Way | 3 | 11th June 2009 03:12 AM |
| Help needed building loudspeakers | sogens | Multi-Way | 6 | 5th October 2007 07:11 AM |
| Building ur own loudspeakers | idarwin | Multi-Way | 26 | 8th January 2006 09:27 PM |
| building 5 way outdoors loudspeakers | ahdcfegb | Multi-Way | 1 | 28th June 2004 02:15 AM |
| loudspeakers | konky | Multi-Way | 14 | 14th February 2004 11:22 PM |
| Page generated in 0.10283 seconds (73.81% PHP - 26.19% MySQL) with 11 queries |
