I'm seriously thinking about making spherical enclosures for my speaker project. Preferably, using concrete.
Anyone ever done this before? I can't quite figure out how to make molds and stuff. Thanks in advance!!! |
#2 |
hi roch
i´m interested too in designing something spherical. if possible i would choose the seas Tr18. a coax is probably the only choice, or you take some broadband driver. for the enclosure my idea would have been to take glass-fiber or sliced wood in shapes that build a sphere together. the fiber should be reinforced with wood too. no more thoughts about it at the moment. greets |
#3 |
I've forgotten the name of it, but there is a tube that is used for pouring cement columns,.......Spiro-tube, or something to that effect. It has been used several times recently by DIYers. I assume it is strong enough to work for you, and you can get it in different diameters too.
Oh, I remember, SonoTube. I assume that you can get it locally without any trouble. |
#4 |
I designed these for a project at work...
Fostex F200A in a steel sphere Once damped these sounded amazingly fast and open. I wish I could afford a pair for use at home! |
#6 |
Nice low tech solution.
Get a sphrical object of a size your like.... stryo ball, beach ball or etc. Can't find the right size, then make one of paper mache. Then lay up a fiberglass cloth and resin shell over the ouside of said object. Test first to be sure your resin doesn't ruin the form. When done, either dig the form out of the shell or split the shell, remove the form and reglass the shell, adding driver mounting details in the process. Cyclotronguy |
#7 |
Magneto the Gravity Man
Someone on the forum recently suggested wooden bowls from IKEA use in pairs to form a sphere.
Somewhere at home I have an article re:- building speakers from styrofoam spheres used in handicrafts. It used a small and medium for the tweeter and mid with a trapezoid box for bass. |
#8 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#9 |
Ok, I did a google search on Sonotube and speakerbuilding and I came up with the following:
Building a Sonotube Subwoofer Sonotube FAQ for speakerbuilding This one is from AudioKarma, and is about 5 years old, Building an Acoustic Wave Cannon Sonotube Sub Design Help Where to buy Sonotube for building a subwoofer? DIY Project # 11 - A Subwoofer Made from Sonotube and the Hsu 12" Driver - September, 1999 And from right here at DIY Sonotube RL-p15 Project with questions... "SDSS 1.1" Single-Driver, Ported Tube Speakers Ok, that should be enough for anyone as a starter. YOu can Google for more information. Just insert Sonotube in the search, and you will find much more. |
#10 | |
frugal-phile(tm)
SonoTube is good for building circular prisms, but i don't know how you'd use it for a sphere. BTW the SonoTube people are quite aggressive about the use of the term SonoTube as a generic name for cyclindrical cardboard forms. dave
| how to make spherical wood horns, step by step | angeloitacare | Multi-Way | 0 | 29th May 2007 01:50 AM |
| Jordan VTL enclosures- make me an offer | neil_kaye | Swap Meet | 5 | 30th December 2006 11:10 PM |
| Spherical horns | AuroraB | Multi-Way | 17 | 10th October 2006 02:32 PM |
| What properties make a good driver for TL enclosures? | Puggie | Multi-Way | 7 | 24th November 2004 07:15 PM |
| ANother way to make curved enclosures. | Hybrid fourdoor | Multi-Way | 5 | 30th June 2003 10:14 AM |
| Page generated in 0.11540 seconds (79.41% PHP - 20.59% MySQL) with 11 queries |
