Old 5th February 2008, 09:04 PM   #11
pdan is offline pdan  Europe
I hope that this is not an imposition, but could you give an account of what you mean when you use the word 'tone'. The imposition is purely selfish on my part as your thoughts would greatly enhance my education. Another esteemed creator, Sakuma, talks mysteriously about the " frame of tone" What is this "tone"? What is it you are both looking for?
Cilla
Old 5th February 2008, 09:19 PM   #12
AdamThorne's Avatar
I have spotted your experimentation with this driver on a few different threads. I'm not personally in a position to have such large speakers in my living room, but I like to hear about a large and efficient midbass. Hopefully the experimentation with this driver will continue!
Old 5th February 2008, 09:33 PM   #13
Banned
This is my take not the standard definition by any means - Tone is the entire structure of the instrument from the initial leading edge attack and it's harmonic make up and decay all bundled into one envelope of energy. To me it it is an ever ending? challenge to get a complete envelope. When we hear the bow go across the strings of the cello for instance we get the entire envelope, the cello has the warmth of the spruce and maple from it's body the strings are of gut and the bow is carbon fiber - just like the original. To hear this live unamplified is a beautiful heart warming experience that is complete or whole. To achieve this energy envelope in a home playback system, as in the entire envelope and feeling is the pinnacle of tone. Pick any instrument or vocalist - the cello was only an example. To have it reproduced without the connection of the entire envelope leaves me unsatisified, unfullfilled, and empty of the true meaning of the music. Can it be done completely as in the entire energy envelope? With the right recording it can sometimes be somewhat believable. Using high efficiency drivers, boxless enclosures, and a good front end seems to get most of the envelope in my room.
Old 5th February 2008, 09:41 PM   #14
ttan98 is offline ttan98  Australia
Default Re: Re: Re: Sensitive Wide Range OB - Update - Tonemaster
Originally posted by Magnetar
It's not exactly neutral but measures really flat in the midrange - I have more accurate midrange drivers like the JBL 2123 that sound very good but don't sound like this. An analogy would be the accurate JBL sounds like a good solid state amplifier where the Lil' Buddy sounds like a direct heated single ended 45 triode amp. In other words it's fast, direct, warm, lush and romantic. More 'whole' - probably has just the right amount of even harmonics distortion to please me.....
The mod is simply removing the dustcap and installing a phase plug - the plugs in mine are temporary - made from wax.. The driver uses hemp for the cone and has hemp for the surround - it's different
Thanks sounds interesting I may try it one day as the cost of the driver is not too expensive.
The Hempcone I tried from Hemp acoustics sounds a little dark and also it has a dip in the mid range even though the bass is very good.
Old 5th February 2008, 09:43 PM   #15
Banned
The driver shouldn't really be considered midbass in this application. I use it solely as a midrange. The bass is all handled by the other five ten inch woofers. They have the ability to move much more air in the lower frequencies then the single Lil' Buddy. That's what you need to 'keep up' with the driver used as a midrange.
Old 5th February 2008, 09:47 PM   #16
Banned
Default Re: Re: Re: Re: Sensitive Wide Range OB - Update - Tonemaster
Listening to the driver by itself fullrange it is dark, but on an open baffle used as a midrange it has what I'll call high midrange resolution density or HMRD
Old 5th February 2008, 09:56 PM   #17
Thank you very much. Your concise clarity has helped me a great deal.
Old 5th February 2008, 10:41 PM   #18
Banned
It really is much deeper then this from a home playback point of view - for example look at the radiation of a cello at different frequencies/notes/harmonics - it is very complex - the ability to fully capture this with a microphone (as well as the other 11 cellists and the rest of the orchestra ) and play it back with the entire energy envelope in tact is asking a lot. - I find that many of the older simpler miked recordings are superior
The dipole radiation and lack of most box colorations imposed upon the envelope helps in my experience from a speaker/room perspective but you also must have the dynamics and feeling of ease of the real thing. The dynamics are a big part of the energy envelope. This requires moving lots of air with as little compression of the envelope as possible. Most speakers and home 'high end' systems fail miserably in this respect.
Old 5th February 2008, 11:19 PM   #19
Banned
Loudness curves for two violins. The upper curve represents a fine Stradivarius, while the lower curve represents a relatively poor-quality violin. W represents the main wood resonance, A represents the air resonance, and W1 represents the wood prime resonance. (From "The Physics of Violins," by Carleen Maley Hutchins. Published by Scientific American, Inc.)
Sound radiation patterns at four resonant frequencies of a Martin D-28 folk guitar. In all three patterns, the sound hole is pointing downward. (From "Sound Radiation from Classical and Folk Guitars," by J. Popp and T.D. Rossing.
Old 6th February 2008, 01:36 AM   #20
Default Re: Sensitive Wide Range OB - Update - Tonemaster
Would you mind telling a bit more about your woofers?
Francois
New 8'' wide range speaker Igor V. Kutuzov Full Range 73 2nd November 2010 05:46 PM
Sensitive Wide Range Open Baffles Magnetar Multi-Way 179 19th March 2009 08:31 PM
Wide dispersion speakers using full (wide) range drivers ozziozzi Full Range 1 28th December 2008 06:13 AM
wide'ish range driver? dunderchief Multi-Way 1 17th July 2004 11:27 PM
Copyright ©1999-2013 diyAudio
