Old 25th January 2008, 04:44 PM   #1
Default WR125 combing with MTM or TMM
Hi guys,
I have seen a few speakers using the WR125ST from CSS as an MTM or TMM kind of setup like these,
http://us.alegriaaudio.com/RosaLCR.htm
http://www.timn8er.com/alegria_audio_rosa_tl.htm
The first one in the list is crossed over to the tweeter at 3kHz with a 4th order crossover and the second one is left wide open on the WRs and has the tweeter cut in around ~14kHz with a 1st order crossover.
I was thinking of building a box with two of these in it around 1 cft sealed. The -3db point on the system would be 80 Hz making it easy to crossover to a sub. What I was wondering is about the top end. I have looked all over for the formulas and theory on combing with two speakers producing the same frequencies but I can not find it. Is it all right to leave the WRs run fullrange with the tweeter cut in high or is there a level where it should be rolled off on the WRs to avoid combing? I would orientate the WRs like that of the second link so that the frames are right against each other.
This is the tweeter I would probably use snuggled up right close to the frames where the speakers comes together right before it flattens out.
http://www.partsexpress.com/pe/pshow...number=275-025
The guys using the Pioneer B20 seem to love this tweeter.
Old 26th January 2008, 12:11 AM   #2
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
FYI, Use ArrayShow to model the vertical combing for the suggested TMM: s where only the T driver is using a low filter.
Look at the submitted 3 simulations and note that the filter phase at the chosen frequency is expressed in time delay instead, or as the T phase at 4 kHz is chosen to be = 180 degrees, with the polarity switch instead in use.
Where you place your crossover point is a matter of preferences, in the first polar plot you can see the vertical dispersion of the TMM: s suffering from combing, even as low as at 4 kHz if the T driver too is in phase with the MM: s
b
1(1)
So now, combing isnt a problem in an array? amt Full Range 146 13th April 2009 12:28 AM
How bad is the combing effect using multiple mids? swak Multi-Way 8 18th August 2007 01:58 PM
Wr125 Mtm dawaro Multi-Way 3 7th November 2006 10:31 PM
Wtb: Wr125 bjackson Swap Meet 0 8th November 2005 03:50 PM
Page generated in 0.07493 seconds (69.88% PHP - 30.12% MySQL) with 11 queries
