Reality Check - Page 2 - diyAudio
Old 26th January 2008, 03:47 AM   #11
jnb is offline jnb  Australia
If you use the manufacturers reponse plot then you should add baffle step diffraction and the effect of the box on the bass. Both can be simulated and each can be added either before SPLtrace using a drawing app, or after using a text editor.
FWIW, you should find this compares surprisingly well with what you measure.
Old 26th January 2008, 05:55 AM   #12
DcibeL is offline DcibeL  Canada
DcibeL's Avatar
Proper use of FRD tools, simply tracing the FR and impedance is not enough. Also, please take Sreten's advice about using two dome mids and isobaric driver configurations.
The power of Science compels you!
Specs VS reality ecl86 Subwoofers 2 20th September 2007 02:07 PM
Crossover Reality Check??? jocko_nc Multi-Way 1 6th February 2007 09:21 AM
tube amp layout reality check zobsky Tubes / Valves 5 10th August 2005 04:20 PM
Acoustic Reality Ear 2 Amp Harmon Digital Source 33 17th February 2005 09:16 PM
Reality check analog_sa Chip Amps 2 10th November 2003 09:30 PM
Copyright 1999-2017 diyAudio
