what might work in minimal bulk to get nice solid drumkit sound without resorting to bulk of horns? will some larger woofer with Linkwitz transform get the kickdrum?
how large of a midrange direct radiator does it take to get some snare snap? ideally the speaker would be acceptable on all music genre. |
#2 |
I always think that kickdrum sounds best on sealed cabs, they don't even have to be so large as too much real sub just muddies things up, something that rolls off at around 50 Hz would probably sound better on kickdrum than a cab with extension to say 35Hz. For that reason I wouldn't think a LW transform to be necessary. On the other hand you say minimal bulk so depending on size of venue it's unlikely you'll get levels required qithout a fair few boxes.
Maybe one or two biggish 15/18" horns stacked would do it for you..like I said, depends on size of crowd as to how much of x cab you'll need. |
#3 |
it would be for home use - I have Karlson couplers but would like to have something different for a change.
#4 |
Sealed can kick well, but they do really suck up the power.
(perhaps even more than theory suggests) |
#5 |
Theory is spot on, just most folks apparently don't understand the theory.
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#6 |
so whats the theory of why sealed cabs suck up so much power ?
#7 |
Folks seem to think that since the cab is rolling off the low end it's not using much power, but if it's getting a high amplitude signal the driver is trying to reproduce it against a high box compliance, heating up the VC, which draws more current, etc., etc.. I^2T rules until the amp starts clipping or the VC blows open.
#8 |
This problem could surely be countered by using a steep high pass filter.
#9 | |
#10 | |
| Modest Challenge for XO Experts | 4yanx | Multi-Way | 4 | 4th February 2007 06:08 PM |
| Which modest $ FR setups play drumkit really well? | freddi | Full Range | 2 | 19th November 2006 01:32 PM |
| ESL diaphragm contact approaches | Few | Planars & Exotics | 11 | 7th July 2006 08:47 AM |
| First project. Sealed modest Sub. | ShockValue | Subwoofers | 3 | 18th January 2005 12:13 AM |
| Modest IGBT SE project | pjacobi | Solid State | 0 | 1st February 2004 10:57 AM |
| Page generated in 0.09046 seconds (78.27% PHP - 21.73% MySQL) with 11 queries |
