Old 23rd January 2008, 10:37 PM   #1
Default speaker's BL parameter
does BL force factor parameter provide any useful information about speaker's performance? I noticed that high-end pro woofers have higher BL, and their sound is often described as more dynamic.
does it mean higher the BL the more dynamic driver is? or there is no direct relation.
Old 23rd January 2008, 11:12 PM   #2
Svante is offline Svante  Sweden
Svante's Avatar
BL is simply the amount of force on the cone you get for a certain current through the voice coil. A higher Bl will make the driver play louder (but not necessarily cleaner) and it will also indirectly lower Qes and Qts.
Bl has to be viewed together with Re since it has the opposite effect. That is why the ratio Bl/sqrt(Re) is sometimes found in datasheets.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 24th January 2008, 04:38 PM   #3
Thawach is offline Thawach  Thailand
Thawach's Avatar
Hi svante
Thia picture that i have ever seen. What do you think about this?
They want the spl or not?
regards
Thawach
______________________________________
The cheap materials and good engineering. Please believe
it's the garbages from good engineer. a salesman.
Old 26th January 2008, 07:03 PM   #4
Thawach's Avatar
Hi svante
I ask you at 2007. and here is 2008. (about 1 year)
I cannot get the answer from you.
Are you sleeping? woo!
regards
Old 26th January 2008, 08:54 PM   #5
Svante's Avatar
Hmm, I am afraid I don't understand the question.
Old 27th January 2008, 09:58 AM   #6
Thawach's Avatar
Hi svante
I would like to know that they make it for?
If you are not answer me. I will download The adge and Basta
to use.
2009?
Old 27th January 2008, 10:58 AM   #7
Can a member from Thailand help Thawach rephrase the question/s?
regards Andrew T.
Old 27th January 2008, 11:12 AM   #8
ßart West-VL.'s Avatar
I think the question from Thawach is, "What is the driver meant for, high spl?"
Bart
Old 27th January 2008, 12:03 PM   #9
Thawach's Avatar
Hi
i want to know that it's difference from single magnet.
I see the picture . it has magnet to join=3.
the gap is long. i would like to know what the parameter change?
is it good idea?
regards
Old 27th January 2008, 02:42 PM   #10
Zoran is offline Zoran  Serbia
BL=B x L (Tesla x meter)
where
B = strenght of magnetic field
L = lenght of voice coil vire
Multimeter for T/S parameter Buzzy Multi-Way 21 9th May 2008 05:13 AM
Which is the most important TS parameter? Wombat2 Multi-Way 7 19th July 2006 12:27 AM
parameter translation please KevinTams Multi-Way 4 10th September 2005 10:44 AM
Tube parameter ? woody Tubes / Valves 2 7th April 2004 07:35 AM
Req. What does this parameter mean? stigla Tubes / Valves 9 7th March 2003 08:40 AM
Page generated in 0.09797 seconds (79.15% PHP - 20.85% MySQL) with 11 queries
