Hello all,
I am starting a new project soon, and am just getting together my cx parts. My problem is finding a 16 Ohm resistor with enough power handling to work in my woofer circuit. I am a noob at most of this, but from what I have read recently, I figure that if I wire 2 8 Ohm 12 watt resistors in series, this will give me a resistance of 16 Ohms and a power handling of 24 watt. Am I correct??? Any help would be greatly appreciated. Thanks |
#3 |
In as far as you have told us, you are correct, but I think the deeper question is where and why are you putting a 16 ohm resistor in your woofer circuit?
I'm not saying you can't or shouldn't do that, but a few more details would help us understand. Still, perhaps we don't need to understand, but you say you are a beginner and people here can offer a great deal of help and advice. At the core of it all, two 8 ohm 12w in series indeed does equal one 16 ohm 24 watt resistor. Steve/bluewizard |
#4 |
My reasoning on using the 2 8 Ohm resistors is to reach the 16 ohm requirement and increase power handling. I have read that a resistor in a woofer circuit requires a power handling of 15-20 watts. Is this not correct?
As I said before I am new at this, and it's definitely a learning experience. Below is a pic of the crossover. |
#5 |
hi
you're correct. |
| Three 10" 4Ohm subs, wired in series or series-parallel? | Nagamitsu | Car Audio | 24 | 10th May 2009 03:24 AM |
| series or parallel? | medicman | Tubes / Valves | 5 | 22nd January 2009 04:42 PM |
| Series vs parallel? | legendaryfrog | Full Range | 5 | 14th December 2006 02:50 PM |
| What would you do? series/parallel | MtnBob | Multi-Way | 13 | 14th April 2005 10:17 PM |
| Page generated in 0.08162 seconds (74.45% PHP - 25.55% MySQL) with 11 queries |
