Hi All,
I have a pair of Alcone AC8HE woofers and I'd like to use them in my next project. Only question is about bass loading because they appear to be good performers wherever I put them to. They will play in relative small room at moderate levels. SQ is most important. Should I use them in closed or vented enclosure (or any other)? Datasheet is attached. Every suggestion is welcome.
Regards Robo |
#2 |
Given that you cannot use them easily in a 2 way I'd go 3 way. Around 60L to 70L tuned to 30Hz goes low. |
#3 |
Sreten,
thanks for your quick reply. Anyway, this woofer will be used in 2-way loudspeaker. My major concern is a little high Qts, so I don't know if it's better to put it in closed box or it's still good for vented.
Regards Robo |
#4 |
It will do allright in a two way. I use it with a Dynaudio D260 Esotec.
http://www.lautsprechershop.de/hifi/...fourier_en.htm |
#5 | |
If it's possible, could you please show me crossover schematic. Thanks
Regards Robo |
#6 |
As far as I remember it is the same as the woofer section in this link; http://www.audioaktiv.at/fourier.htm
Tweeter part is different ofcourse. |
#7 |
You can use it easily in a 2-way by sticking your head in the sand. http://www.zaphaudio.com/audio-speaker17.html See the discussion on distortion issues of metal cones here. Seas L18 : note the twin peaks in all distortions due to driver response The discussion concentrates on F3, it can be seen to be OK below 2KHz. If you start worrying about F5 do not use metal cones in a 2-way. Now drop the cone break up an octave as in this case. Note that the c/o has no effect on the distortion produced by fundamentals. The drivers also work fine in 30 to 40L sealed. |
#8 | |
#9 |
Sreten,
I know about it (anyway, each driver is different), but I bought these drivers few years ago, if I buy drivers now, I'd buy paper or PP coned woofers (CA22RNY looks great for me). I just want to use them in some project and I'm not experienced enough to try to go 3-way. I'll try to get XO as low as possible as I use waveguide tweeter, maybe it will help. Thanks No sand here around, may I stick my head to concrete wall?
Regards Robo |
#10 | |
Presumably there are no Ostrich's around either. http://www.rjbaudio.com/Audiofiles/FRDtools.html http://www.geocities.com/woove99/Spkrbldg/ Your 2 way is more difficult than a 3-way, square pegs into round holes and all that ..... |
| New bass loading technique ? | ashok | Multi-Way | 27 | 20th April 2009 06:17 AM |
| PLL problem - No Bass and full loading | xitronics | Everything Else | 7 | 15th April 2008 01:00 AM |
| Doe anyone know the Alcone Pascal kit | dublin78 | Multi-Way | 0 | 15th May 2006 08:17 AM |
| Alcone (RCM) BX10 | TSE | Subwoofers | 2 | 14th March 2006 06:38 PM |
| Alcone low/mid driver | Kees | Multi-Way | 3 | 21st October 2002 06:43 PM |
| Page generated in 0.10676 seconds (78.99% PHP - 21.01% MySQL) with 11 queries |
