crossover Audio transformers
Old 24th February 2003, 05:10 PM   #1
macka is offline macka
macka's Avatar
Default crossover Audio transformers
Does anyone have any experience with using tapped crossover chokes which act as an auto transformer?
I am refering to some of the older JBL/Altec networks that were either iron or ferrite cored and were tapped to provide some attenuation for the highpass network rather than a L pad.
Ian
Old 25th February 2003, 05:15 AM   #2
Nappylady is offline Nappylady  United States
Nappylady's Avatar
Send a message via ICQ to Nappylady Send a message via AIM to Nappylady Send a message via MSN to Nappylady Send a message via Yahoo to Nappylady
I once ripped apart a theatre organ with such a setup...
it was really bizarre. In order to get a high-range speaker, they took a 12" woofer and misplaced the magnet so that the voice coil was pinched. The woofer then would only respond to high frequencies. Then there was a transformer before the 15" low-range speaker (which I actually still have, if I could only find a good use for it.) It was a truly bizarre setup.
Old 26th February 2003, 12:10 AM   #3
cyclotronguy is offline cyclotronguy  United States
Default Auto-formers
Yup! Look up ALK Crossovers on the web. In certain applications they work quite well.
Cyclotronguy
Old 26th February 2003, 12:30 AM   #4
jam is offline jam  United States
jam's Avatar
Cyclotronguy,
Working late tonight?
Jam
crossover Audio transformersHide this!Advertise here!
Audio Transformers - Help gingertube Tubes / Valves 3 15th July 2009 09:09 AM
Sun Audio transformers Toropkin Tubes / Valves 9 28th September 2008 11:37 AM
Audio Transformers 101 dsavitsk Tubes / Valves 2 5th January 2008 11:20 AM
Car audio SMPS transformers Toddy Audio Swap Meet 6 13th August 2004 03:39 PM
Old little audio transformers miguel2 Tubes / Valves 1 13th June 2003 08:53 AM
Copyright ©1999-2017 diyAudio
