Old 15th January 2008, 07:51 PM   #1
sdclc126's Avatar
Default 2 Woofers = 2 x Volume = What Port?
If this has been answered before (maybe in Subwoofers) I apologize, but I couldn't think of good keywords to search with...
I know that if you use two woofers, either midwoofers or for "dedicated" bass, you should double cabinet volume to achieve the same tuning as for a single woofer. But what then happens with port size calculation? Does that also double? Or?
Thanks.
Soft Dome
Old 15th January 2008, 07:57 PM   #2
Did it Himself
richie00boy's Avatar
Everything doubles. You simply use two of the ports that you specced for the single size box. Or one port of the same cross sectional area.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 15th January 2008, 08:13 PM   #3
sdclc126's Avatar
Thanks Richie,
It's nice that it's that simple and straightforward - makes for a short thread though.
Soft Dome
Old 15th January 2008, 08:31 PM   #4
I don't think it is simply 2 ports at the same length as a single port (unless the spreadsheet I am using is wrong). I don't have the formula handy. To maintain the cross sectional area by adding another port - don't you have to almost double the length of both ports for the same tuning frequency?
Old 15th January 2008, 08:57 PM   #5
Did it Himself
No it's simply a double up on everything, port length remains as per a single woofer box. Think of it as two single boxes joined siamese style.
Your last sentence does not make sense by the way, but I know what you are trying to say.
Old 15th January 2008, 09:06 PM   #6
Jay_WJ is offline Jay_WJ  United States
Dave, what you said is correct only when the box volume stays the same. If the box volume is doubled, you can achieve the same port tuning frequency by adding a port of the same length.
Old 15th January 2008, 09:20 PM   #7
Svante is offline Svante  Sweden
Svante's Avatar
Yes, two drivers, double volume, two ports of the same length is correct. However, the port needs to be slightly shorter if a single port is used due to that the end correction becomes larger for a larger diameter port. Actually, if the two ports are placed close to one another, there will be an effect in this direction too since the ports share co-oscillating air.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 15th January 2008, 09:32 PM   #8
sdclc126's Avatar
Maybe I spoke too soon.
Soft Dome
Old 15th January 2008, 10:28 PM   #9
Ooops - yeah that was a bit dumb of me - cheers guys.
Old 15th January 2008, 10:57 PM   #10
Could you elaborate on end correction please?
~Brandon
DriverVault Soma Sonus Old Driver Tests
Newbi: Box Volume and Port Length 69stingray Subwoofers 14 22nd April 2005 02:57 AM
To port or not to port? Newbie with newly built mains starquake Multi-Way 1 18th December 2004 12:51 PM
Round VS Shelf port volume Mick M Multi-Way 1 20th November 2004 05:44 AM
Need Volume And Port Size For Norh 9.0 sardonx Multi-Way 0 1st August 2004 02:44 AM
Question about port volume dveous Multi-Way 3 7th July 2004 07:24 PM
Page generated in 0.09271 seconds (79.96% PHP - 20.04% MySQL) with 10 queries
