Good speakers for a low power receiver?
Old 13th January 2008, 08:50 PM   #1
Maxxarcade is offline Maxxarcade  United States
Default Good speakers for a low power receiver?
I am looking for opinions on which (affordable) speakers would work well with a Pioneer SX-434, which has 15W per channel RMS.
I am currently using Sony SS-MF400H speakers, but I would like something that is just a bit more efficient.
This receiver has a great, wide stereo sound to it, so I'd like to match it up with an ideal pair of speakers. It will make the Sonys loud enough to feel in my chest, but at the expense of tight response.
I'll probably put the Sonys on my SX-780 when I get it next week.
Old 13th January 2008, 09:55 PM   #2
jnb is offline jnb  Australia
Have you looked at Fostex?
Old 13th January 2008, 10:17 PM   #3
All I've been able to find are powered speakers... Any passive ones I've seen are really expensive.
Old 13th January 2008, 10:32 PM   #4
Sorry if I don't know what would be expensive in your country. These are $45.
Madisound
Old 13th January 2008, 10:51 PM   #5
lousymusician is offline lousymusician  United States
What counts as affordable?
This being a DIY forum, how involved a building project can you take on?
How big is your room? What's the layout like?
Insert witty signature line here.
Old 13th January 2008, 11:13 PM   #6
The room that I currently have the receiver in is 20x9. Though it is my workshop, so it won't be staying there too much longer.
I only paid $30 total for the receiver, so I don't really want to pay more than $100 or so for a used pair of speakers.
I can build stuff DIY, but I don't have the tools to make my own boxes from scratch yet.
I do have a pair of Kenwood JL-670 speakers that sounded good with it, but they need a lot of work (new tweeters, woofers, and some box repairs.
Old 14th January 2008, 10:34 PM   #7
mashaffer is offline mashaffer  United States
As an open baffle convert can I suggest that you consider making a simple (say full range with helper woofer) on open baffle. Since the "box" you have to make is just a board with a hole in it the tools needed are minimal. Just find a nice fullrange with decently high Q and moderate sensitivity (not really high sensitivity because you xover will just have to pad it down) and add a high Q woofer with sensitivity not too much lower than your FR. Simple 2nd order crossover and you are in.
Parts express sells quite a few high Q woofers under the Goldwood brand name. They are cheap but they work. PE also has several nice wide range drivers in the 3 to 5 inch range.
Might just do the trick for you. For best results a 12 or 15 inch woofer would work best I think. I use a 10" in my system but I am biamping. Another thing you could do if you receiver does not mind 4 ohm loads is to use a 4 ohm woofer and 8 ohm full range and compensate in the crossover design.
just some ideas.
mike
Old 14th January 2008, 10:48 PM   #8
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
If you are not set up to build a cabinet, have you considered something from a thrift shop or is this something you wish to keep for years to come?
planet10 needs your help:
Let's help Ruth and Dave
Old 14th January 2008, 11:01 PM   #9
I just picked up a nice old set of Zenith Allegro speakers, rated at 40 watts. Haven't tried hooking them up, but they just may be what I need for the SX-434. For $5, I'm not going to complain.
I also got a nice older Pioneer turntable to go with my SX-780, and I'll be pairing that up with a bigger set of speakers once I can afford them.
Old 14th January 2008, 11:11 PM   #10
Ron E is offline Ron E  United States
Ron E's Avatar
If you like Pioneer, look for some HPM series speakers. My brother had HPM-60's and they were quite efficient (Loud).
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Good speakers for a low power receiver?Hide this!Advertise here!
FS: Speakers/Receiver/DVD +more Dougie085 Swap Meet 1 11th October 2007 02:02 PM
Using 5 channel receiver for stereo sub and speakers renfrow Subwoofers 7 21st September 2006 02:17 PM
Which Cd receiver is good? gonglee Car Audio 12 14th April 2005 06:27 AM
Chip amp good to power outdoor speakers? Tsanford Chip Amps 1 5th July 2004 02:38 AM
AV receiver suggestion for DIY speakers? Keith TDI Everything Else 4 25th March 2002 11:51 AM
